Author Topic: check my translation of pedal trick light flashes?  (Read 1712 times)
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« on: 15 January 2013, 14:35:28 »
1,  5,  4,   10
1,  5,  3,   10
10
someone want to tell me what error code i should be looking up ?  (it's an astra ,  but past experience tells me the reading of the codes is the same,  just need to be looked up on the right engine / car code sheet.  )
damn thing will not start.....   was running fine yesterday.
Re: check my translation of pedal trick light flashes?
« Reply #1 on: 15 January 2013, 14:43:18 »
I suspect the 10's are at the wrong end and that should be P0154 and P0153 - both are O2 sensor codes (former is 'no signal' and the latter 'slow response').. assuming this is a car late enough to be using OBD codes, of course.
« Reply #2 on: 15 January 2013, 14:53:11 »
Most engine codes seem to start with zero/10 flashes.
Ime it helps to video the flashes, then you can pause, write down, play etc.
MaxV6
  • Oxford UK
« Reply #3 on: 15 January 2013, 14:53:17 »
i am confused by the lack of a long 10 sequence at the start, (could just be lack of familiarity)   the 1 is definitely the first flash i get....
« Reply #4 on: 15 January 2013, 14:55:12 »
Always a chance that it's not flashing OBD codes but proprietary ones - what age Astra is it?
Hopefully someone with Astra specific knowledge will be along in a bit..
MaxV6
  • Oxford UK
« Reply #5 on: 15 January 2013, 14:56:30 »
i wrote down the flash sequence....    i'm used to doing similar things for work...     dfinitely 1,5,4,10 ,  1,5,3,10,10
« Reply #6 on: 15 January 2013, 14:57:08 »
Code seems common via google, is it a Diesel?
« Reply #7 on: 15 January 2013, 15:01:28 »
I see 1530 and 1540 listed as more than one description searching specifically for Astra stuff, IIRC anything with a number that high is in the "Manufacturer makes it up as they go along" range though?
MaxV6
  • Oxford UK
« Reply #8 on: 15 January 2013, 15:39:11 »
Z16SE    engine  petrol 4 pot...
codes i have for it are all Aircon related.....  which surely wouldn't stop the thing from starting up????
« Reply #9 on: 15 January 2013, 18:28:05 »
OBDII are in following format...
Pnxxx
P=drivetrain
n=0 for "standard" OBDII, 1 for manufacturer specific
xxx=rest of code
« Reply #10 on: 15 January 2013, 19:24:16 »
This is a useful site for decoding DTC's .. even the manufacturer "specials" .. although I have no idea how accurate some of them are !!
http://www.obd-codes.com/trouble_codes/
unfortunately being a Canadian site it seems to ignore some European makes
This site
http://www.engine-light-help.com/gm-trouble-codes.html
lists 1530 and 1540 however .. might help ??
« Last Edit: 15 January 2013, 19:29:33 by Entwood »
« Reply #11 on: 15 January 2013, 19:32:30 »
A/C clutch and/or A/C pressure, according to TIS. Doubt it would affect much.
