Author Topic: should i fix or break  (Read 4014 times)
sport
  • Stoke on Trent
« on: 15 January 2013, 22:20:32 »
My omega 2.2 estate 03 good condition everything working but my cylinder head just started to leak been told it will cost between £400 to £500 to fix so is it worth fixing or sell for parts.
Just past mot and 4 resent tiers  £520
Re: should i fix or break
« Reply #1 on: 15 January 2013, 22:24:20 »
I would fix it... What are you going to get for £500? Or DIY/one of the mobile mechanics on here for about half that ;)
Just seen your location... Darth Loo Knee territory ;) Not sure if he's still tinkering but worth asking him :y
symes
  • oxford
    • R reg 940 volvo
« Reply #2 on: 15 January 2013, 22:26:30 »
Well up to you mate but few on here have done head then had other problems 1 felle gave up sold it and left forum :'(
Am thinking that 2.2 is not all that good=now wait for others to lynch me-I got 2.5 v6-engine too complicated for what it is BUT its done 240250 miles so far  :y :y 2.2 would be in bits by then
flyer 0712
« Reply #3 on: 15 January 2013, 22:37:35 »
If you like the car...know the car...then simples fix it...as they said on here what you going to get for £500.....sweet   nothing. :y
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #4 on: 15 January 2013, 22:40:17 »
Easy fix that, nowhere near £400- £500 if you get darth to fix.. normaly poor coolant maint does for head gaskets on the 2.2.
Jaguar XJ6
philsteward
  • Leeds, West Yorkshire
    • 2001 2.2CDX Estate LPG
« Reply #5 on: 16 January 2013, 00:35:20 »
I have just finished changing the head gasket on my 2.2, it had gone on cylinder 3 between the cylinder and the coolant channel so pressurising the expansion tank.
Strip down was straight forward following the guide on here, took no more than 6hrs and I had LPG to contend with.
Got the HG set from Trechii on eBay, very good and recommended on here.
Got head skimmed, pressure tested and stem seals changed for £100 at a local specialists.
Cleaned throttle body, breather pipes, blanked EGR, , changed leaking exhaust manifold gasket, cleaned out cam followers as well.
Rebuilt engine with few issues. Had a couple of problems once finished - misfire on cylinder 3 (injector connector into LPG system had come loose. Also (just solved) the throttle body some how decided to fail.
All finished now, I would say 3 days work plus a couple of days for the head skim and cost me less than £200 including all the extra things I changed/did.
In summary if the car is otherwise good get it done, if you don't fancy it and want rid PM me you never know! ;)
« Reply #6 on: 16 January 2013, 01:06:48 »
Agreed, this is on Daz's doorstep and he would do you an good deal I'm sure on changing the HG.
If Daz is not available I'd happily help you, instinct tells me it would be around half the cost you've been quoted..
car5car
  • Florida USA
    • 01 Cadillac Catera
« Reply #7 on: 16 January 2013, 02:25:09 »
Turn head upside down (remove cam) and fill combustion chambers by ATF to check valves.
Head on the picture is from 02 Saturn 2.2 Opel engine, probably what you have (I mean, your engine has :)).
As you can see 2 cylinders had leaking valves. I had to lap valves by drill. Exhaust valves will leak ATF through exhaust manifold holes, guess where intale valves will leak. ;D
http://s213.beta.photobucket.com/user/car6car/media/head001_zpsa422dfed.jpg.html
« Last Edit: 16 January 2013, 02:42:03 by car5car »
01 CADILLAC CATERA 3.0 engine (Omega)
« Reply #8 on: 16 January 2013, 15:20:43 »
Here's your pic mate -
b4ndit
« Reply #9 on: 16 January 2013, 15:34:43 »
I would fix it as others have said what you going to get for the price of fixing a car you know :y
Sam Burton
  • St Neots, Cambridgeshire
  • Just Car Mad Really
    • Many
« Reply #10 on: 16 January 2013, 15:55:13 »
And plus you always have these guys to help you along the way What more could you ask for
Drives: 2015 Vauxhall Cascada Elite 2.0 CDTI Auto, 2006 Vauxhall Vectra 2.8T VXR 'Ex-Police' Build, 2010 Vauxhall Insignia 2.8T VXR Saloon, 2017 Vauxhall Insignia Elite VX Line Sports Tourer 2.0 CDTI Auto
« Reply #11 on: 16 January 2013, 16:20:58 »
My 2.2 petrol is 13 years old and 160k young, its a bit battered, but gives me a cost equivalent of 50mpg and its dirt cheap to get parts for.
If its head gasket went, I'd get it fixed  :y
« Last Edit: 16 January 2013, 16:24:16 by tunnie »
sport
  • Stoke on Trent
« Reply #12 on: 16 January 2013, 22:06:30 »
Hi loosing water coolant , loads more steam than usual but there seams to be no more pressure than usual in the expansion  tank. and misfires on cold and hot starting for about 5 seconds then runs fine.
« Reply #13 on: 16 January 2013, 22:17:13 »
you will got a lot of steam from the exhaust in this cold weather.Might be worth ruling out other possible causes of coolant loss. :-\
philsteward
« Reply #14 on: 16 January 2013, 22:19:24 »
With the exception of the lack of pressure in the expansion tank that is identical to the symptoms mine had.
Honestly is not too difficult, give it a go!
