Author Topic: Speedo Cluster failure  (Read 4080 times)
Garrath406
  • Ballymena, Northern Ireland
    • 2.2 Omega Diesel
« on: 16 January 2013, 15:12:15 »
Hi, Newbie here  :-\,
I recently bought a 2003 2.2 CD DTI. When driving the car home the entire speedo cluster stopped working (inc. temp and fuel gauge). None of the service lights seem to work either, meaning that when the ignition is turned on, the dash cluster is completely blank, although the full beam, indicator and fog light icons still light. This problem is intermittent as when the car is left for a while, everything works when I return, however will fail in 5 mins or so.
I have researched and discovered that the problem can be related to the ABS, however my ABS light is off and ABS still works.
Any suggestions or help would be appreciated!
Thanks!
Garrath.
Re: Speedo Cluster failure
« Reply #1 on: 16 January 2013, 15:22:47 »
Rmove and reseat it  :y
Nothing to do with abs mate ;)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #2 on: 16 January 2013, 15:24:11 »
Not uncommon for loose / poor connections at the back.
Remove cluster and refit it (easy job!), and may well cure the problem.
Radio & Decoding Technician
www.dndservices.co.uk
b4ndit
« Reply #3 on: 16 January 2013, 15:30:19 »
Welcome to the forum :y
« Reply #4 on: 16 January 2013, 15:41:46 »
If that does not work check either fuses 12 or 15 under the steering column. ;)
Garrath406
    • 2.2 Omega Diesel
« Reply #5 on: 16 January 2013, 17:33:14 »
Thank you so much for your help!  ;D
Will try removing the cluster tomorrow! Hopefully that will cure it  :y
sport
  • Stoke on Trent
« Reply #6 on: 28 January 2013, 09:59:31 »
How do you remove the speedo cluster
thanks
Garrath406
    • 2.2 Omega Diesel
« Reply #8 on: 09 April 2013, 23:26:08 »
Hi, So sorry it has taken me to long to update you on this! I bought a new cluster on ebay costing me £60! Fitted it with great excitement only to discover that it hadn't solved the problem. Of course it turned out to be a simple fuse (which I apparently already checked!).
New fuse put in and cluster works perfectly!
Thanks for all your advice!
 ;D
P.s this forum is much better than the forum I joined when I drove a Peugeot!  :y
b4ndit
« Reply #9 on: 09 April 2013, 23:31:47 »
Glad you are sorted :y
Bixy1
  • Leeds. West Yorks.
  • Hanging by a thread . . .
    • Diesel Vectra eventually.
    • Cats Tails
« Reply #10 on: 19 April 2013, 11:20:58 »
French . . .what can you say .  :-\
Cats Tails (The Adventures of Rommy and Reemy)
http://sbpra.com/derektmorgan
Garrath406
    • 2.2 Omega Diesel
« Reply #11 on: 26 May 2013, 23:12:02 »
Couldn't have put it better myself!  :y
