jump start
Started by Toledodude1973, 16 January 2013, 17:53:06
Toledodude1973
Can someone help with this one please, i tried to start a car using leads from my van today with little success,connected red to red and then neg.(good bat) to point on dead car near engine block. I'm using good quality leads but they just got hot (with some smoke)so i had to abandon it. The dead cars bat. was completely dead not even a dashboard light flicker.Any ideas?
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Toledodude1973
We are starting a corsa with a transit van thanks for reply
Both -ve earth, so should be OK.
Sure leads were right way round? Don't rely on wire colours, check the +ve and -ve symbols on battery.
Quote from: TheBoy on 16 January 2013, 18:03:59
Although that would only be a problem if both cars were earthed
Toledodude1973
The corsa bat seemed completely flat, and apparently pretty new, cables were heavy type, used them many times before, cant understand it
henryd
Quote from: Toledodude1973 on 16 January 2013, 18:08:06
Could be that the Corsa's battery is totally fubar and no amount of power is going to revive it ???
other rides
Toledodude1973
If corsa battery was completely fubar would that cause leads to heat up?
henryd
Quote from: Toledodude1973 on 16 January 2013, 18:44:39
It could do if the battery has shorted itself.
other rides
Toledodude1973
just one last thing ,if when the corsa had a recent new battery the terminals were wired as positive earth what effect would this have on the corsa(sorry or being a bit thick)
martin42
dead corsa,praise the lord  ;D ;D ;D
Toledodude1973
Looks like it must be the battery then,as it had been used that morning thnks for help
Broomies Mate
Quote from: Toledodude1973 on 16 January 2013, 19:11:53
Not possible.  It would not have worked whatsoever with a Pos Earth.
