Another brake light problem for you!
Started by roger.frost, 16 January 2013, 21:20:12
roger.frost
Hi guys. I have the RH brake light not working. I've tried 3 new bosch bulbs, still not working. Just checked terminal block on the light cluster and discovered it has only has 0.3 volts going to the terminal with the pedal depressed. All other lights working fine. Any ideas where to look next.
Many thanks.
Just realised my car details have disapeared!
Omega 2002. 2.2 CDX  Auto Estate
symes
clean up terminals on connector to light cluster  :y
Broomies Mate
Inspect all the terminals on all of the fittings and on the connection block.  It's likely to be grounding somewhere causing problems.
If you have a tow-bar fitted with electrics, investigate that route also.
roger.frost
Many thanks. Have cleaned all the terminals. The low voltage was read at the connector immediately attached to the loom.
No tow bar fitted.
symes
In that case get some wire and connect to l/h brake wire and route across to r/h-had to do that on my salloon
roger.frost
Thanks Symes. Will probably give that a go. The faulty ground sounds a bit like a needle in a haystack.
Broomies Mate
When the brake pedal is off, what voltage to you get?
roger.frost
