Finding Vacuum Leaks....with a cigar
Started by Webby the Bear, 17 January 2013, 13:24:57
Webby the Bear
I looked for vacuum leaks with carb cleaner and to be honest (due to space being tight in the engine bay) I'm not totally satisfied that I did it properly.
Plus there was the worry of it catching fire due to the carb cleaner being flammable.
So I searched a bit and found this....
http://www.youtube.com/watch?v=zMok2y05jNE
What do you think? Anyone tried this?
I'm going to give it a go this weekend.
RIP Paul Lovejoy
I use my ear but dont even start looking unless I have carreid out a vac gauge test to see if there is the need to do the investigation in the first place.
Webby the Bear
That's interesting... never heard of that test.
You reckon this will work for the DIYer? Seems to on the vid  :y
RIP Paul Lovejoy
If its a small leak probably no, I  have never had much success with the carb cleaner one either.
The issue is that when the engine is running there is a lot of  'windage' from the rotating parts such as alternator, aircon, belts etc.
Given the vac leaks are often tiny they dont show up unless its a big one (which you could spot using your hearing)
mantahatch
I find a length of heater hose held to the ear is pretty good. pass the other end round all the joints in the vac pipes and you'll soon hear even the smallest leak.
Worth getting a Lo-Gauge, though, just as a quick way to see if you have a problem in the first place, as said. :y
Webby the Bear
RIP Paul Lovejoy
Quote from: Webby the Bear on 17 January 2013, 13:24:57
Ill have the cigar's when your finished with them  :)
Quote from: Webby the Bear on 17 January 2013, 13:59:15
This is what I found....
http://www.amazon.co.uk/Gunson-G4103-Gauge-Vacuum-Tester/dp/B0012MCW10
Where and how do you hook this up?
Cheers.
That's the chap. :y
If diagnosing the multirams I normally take off the vacuum feed to the solenoid on the front multiram and connect it there. You should see around 0.7 bar / 20In.Hg vacuum there at idle and it should remain static after stopping the engine if there are no leaks and the one-way valve in the vacuum tank is OK.
Webby the Bear
Quote from: Kevin Wood on 17 January 2013, 14:19:12
Cheers.
That's the chap. :y
Thanks Kev.
Sorry for being stoopid  :-[ but where are multirams? Will attaching the device there check for leaks throughout the whole inlet manifold? (plenum, hoses, trumpets etc )
RIP Paul Lovejoy
I found out that cigarette/cigar smoke tests to be successful when there is an air leak (unless fuel was spilled around ;D )  I dont use a hose .. just take some puffs and bring cigarette closer to possible areas and if it sucks the smoke , you find it..
ps: not in a windy day ;D
Webby the Bear
Thats another way of doing it Cem.
I think when I do it (as an experiment) I'll open the throttle butterflies and launch it in the inlets from there. and then try the trumpets too
RIP Paul Lovejoy
Webby the Bear
Right, now I'm home and had a chance to investigate this vac gauge test....
i hook the gauge up anywhere on a vac line between the throttle body and engine, turn on engine and the needle should sit and not fluctuate. correct?
as for where to put said gauge, is this what kev was talking about....???
RIP Paul Lovejoy
Yes, that would be a good place to connect it to check the vacuum supply to the multirams. :y
Webby the Bear
Quote from: Kevin Wood on 17 January 2013, 23:12:07
Thank you mate. Much appreciated.
Will this also confirm vacuum leaks in the whole of the intake manifold or do I need to connect it somewhere else for that?
RIP Paul Lovejoy
