mini cooper s
Started by 78bex, 20 January 2013, 13:03:02
78bex
Hello guy`s, I took a look @ my sister in law`s mini cooper S (2005) this morning.
here`s the problem as diagnosed by the dealer @ the beginning of december.
The car`s engine is making a metallic grinding/ringing noise so it needs a new super charger.
Here`s the actual problem
The air/con compressor clutch has now finally seized & snapped the drive belt.
How easy is it to swap out the A/c pump? is a bunch of special tools required?
The main dealer says they can easily replace the pump when they replace the supercharger!
But the working area in front of the engine is tiny.
martin42
wouldnt have that problem with a Real mini  :y
Quote from: 78bex on 20 January 2013, 13:03:02
LOL  You should work on a real Mini ;D ;D ;D ;D ;)
78bex
I`m almost certain the noisy supercharger will now turn out to be one very knackered A/C compressor.
Easy enough to check, simply pop the belt off and start it for a short period and see if the noise goes.
A truely hateful engine the Chrysler derived Cooper S has though, they drink SO much fuel, the later turbo variant (peugeot?) is SO much better
symes
Quote from: 78bex on 20 January 2013, 20:21:36
+1 :y
