Wanted. Genuine Navteq disc
Started by Elite Pete, 21 January 2013, 18:28:44
Has anyone got a genuine Navteq disc for the NCDC 2013/2015 age unimportant
TIA :y
I've managed to get of off Ebay  :y
zirk
Quote from: zirk on 23 January 2013, 00:28:15
GID or CID version?
Oh bugger, didn't know there was a difference :-[
twiglet
Quote from: Elite Pete on 23 January 2013, 07:13:19
GID or CID version?
To my knowledge, there isn't.   :-\
Quote from: twiglet on 23 January 2013, 08:16:48
GID or CID version?
Just had another look and I can't see anywhere on the box where it says CID or GID all it says is suitable for NCDC 2013/2015s
zirk
The ones Ive come accross from a CID work both, but Ive had some Navtech Disks from a working GID that wont work on a CID, if that makes sense.
twiglet
Quote from: zirk on 23 January 2013, 09:34:31
Are you sure that wasn't an issue with the specific NCDC system you were trying them on Chris.  As far as I can tell, the discs simply hold map data that the NCDC system interprets.  The GID/CID is only a display, and doesn't directing interrogate the disc, so it really shouldn't make any difference.  :-\
zirk
Quote from: twiglet on 23 January 2013, 13:48:59
Dont think so James, in fact if you cast your mind back we also tried the Disk from my Irmy Mig (GID) in your Estate (CID) and it said something like wrong Disk / unable to load, even though it loaded on the GID one, your one loaded on both.
Seem to remember yours was labelled VX/Opel were mine was labelled Navteck. ... I think.
OmegaAnglesey
Would this be any good for a NCDC2013 unit ? :-\
zirk
No idea, bit dubious about his meaning of 'COMPATIBLE', if it means a burnt copy then No, not recommended for the Laser on the HU.
OmegaAnglesey
Quote from: zirk on 23 January 2013, 16:07:48
Thought as much and it must be a copy being that cheap especially for a 2011/2012 version.
zirk
Hmm, if it is a copy, I feel for the people buying them as a cheap workaround.
humbucker
Quote from: zirk on 23 January 2013, 16:29:07
"AS TO AVOID ANY CONFUSION THIS IS NOT A NAVTEQ, CARMINAT OR OEM DISK BUT IS 100% COMPATIBLE WITH THE NCDR/NCDC SAT NAV SYSTEMS"
e.g. knock off
http://www.irmschermv6.com | #irmscherMV6
PM with your requests.
