Author Topic: Fault code p0420  (Read 2375 times)
dazzle72
  • nottinghamshire
    • Omega 2.2 CDX Estate
Fault code p0420
« on: 21 January 2013, 19:21:27 »
Got the blowing exhaust manifold done and had codes re-read today as eml came back on. Something to do with cat efficiency which means we need a new cat so I'm told. Is this correct?? Oh, and since the code read this morning the spanner symbol stays on on start up. Switching off and restarting puts it out.
symes
  • oxford
    • R reg 940 volvo
Re: Fault code p0420
« Reply #1 on: 21 January 2013, 19:24:44 »
does your exhaust have a leak-split on flexi?
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #2 on: 21 January 2013, 19:26:21 »
blowing manifold will cause the engine to run rich which could damage the cat but normally this is over a long period of having a blow.  I would check that the manifold has been fitted correctly as a first port of call
dazzle72
  • nottinghamshire
« Reply #3 on: 21 January 2013, 19:32:44 »
Thanks for the replies guys, most appreciated. Hopefully doing the rocker cover gasket this week with a mate whos more clued up than me, so we'll have a good look
« Reply #4 on: 21 January 2013, 19:35:20 »
Do not replace the cat with an aftermarket one ;)
symes
  • oxford
    • R reg 940 volvo
« Reply #5 on: 21 January 2013, 19:38:14 »
waste of time+money =total rubbish :y
« Reply #6 on: 21 January 2013, 19:54:14 »
Do not replace the cat section. Aftermarket are worse than than a shagged genuine
dazzle72
  • nottinghamshire
« Reply #7 on: 21 January 2013, 20:03:37 »
I'll check whats already been suggested, then re-post with my findings. Fingers crossed it wont need a cat, but thats a bridge to cross if needed
« Reply #8 on: 21 January 2013, 21:21:52 »
0420 .. put some higher spec fuel in .. shell v-max or similar and drive it like you stole it for a tank full ... :)
Not guaranteed to sort it but often does, another way is to put 1600kgs of caravan on the back and go up Birdlip Hill at 50 .. :)  IME that sorts it out really well :) (but don't look at the fuel consumption gauge while you do it !!!)
dazzle72
  • nottinghamshire
« Reply #9 on: 22 January 2013, 15:30:39 »
I'll try different fuel and see what happens. Thanks for the tip
