need some help
Started by martin42, 22 January 2013, 17:05:55
martin42
i need to remove ignition barrel on the escort,can some1 please tell me how to remove it,had a quick look this evening,as getting it ready to swap over ecu etc,thanks :y
zirk
Quote from: martin42 on 22 January 2013, 17:05:55
How old, older ones where Key in and theres a small pin on the side of the barrel, cant remember if you need to push it in or pull out, think its the first.
kevinp58
I think you need to first remove the shroud then put the key in turn to first position and then underneath there should be a pin, push this in with the aid of a pin punch and pull the barrel out with the key at the same time, thats if my memory is right.
martin42
ok cheers,will have a look 2moro evening, :y
henryd
Quote from: kevinp58 on 22 January 2013, 17:10:53
As above but isn't there a grub screw as well ???'long time since I've pulled one of these
other rides
martin42
no grub screw on the mk6
A length of scaffolding will do the trick :D
martin42
Im in car where abouts is this pin on switch??
martin42
found it,barrel removed now waiting for delivery of new ecu etc  :D :D
If you get stuck and need to fetch parts or anything give me a shout mate and ill be over  :y
kevinp58
Quote from: martin42 on 22 January 2013, 18:17:49
:y :y :y
martin42
cheers Steve,all sorted,got van i can use anyway lol,car sitting in garage looking sorry for its self now lol
martin42
it lives again,but now heater blower doesnt work on any speed,another problem to sort out  >:(
Quote from: martin42 on 23 January 2013, 20:37:38
Oh no  :( Is that just a fuse problem or a new blower motor  :-\
martin42
everything working,now to put it back together again,thats for saturday i think :)
