Zafira boot catch fault
Started by philsteward, 24 January 2013, 21:21:30
philsteward
Just wondering if anyone has any suggestions, the car thinks the boot is open, door light on dash is on and boot light stays on.
Not sure how the catch actually works, any suggestions? Of where to start?
Presumably a switch somewhere, normally seperate from the catch on most cars
As above, probably a switch fault. Possibly located in the tailgate :y
henryd
Check that the latch mechanism hasn't worked loose and that the striker plate hasn't as well,if the tailgate is only single latching the light will stay on :y
other rides
philsteward
Thanks all for the information.  Will have another look, couldn't easily see a little probe for the switch, so thought it was some clever internal thing in the lock. Door seems to closing okay, feels tight and no rattle when driving. Cheers
The switch is integrated into the tailgate latch assembly and is actuated by the locking catch.
Test it with the boot open using a screwdriver to latch the catch as this will prove if the switch is ok or not.
Not to hard to fix and you can simply replace the switch as its pretty freely available.
philsteward
Quote from: Marks DTM Calib on 25 January 2013, 11:27:16
Excellent Mark, thanks, how I thought it works, will have a look tonight.
