Author Topic: Washers in-op  (Read 1641 times)
dazzle72
  • nottinghamshire
    • Omega 2.2 CDX Estate
Washers in-op
« on: 25 January 2013, 11:55:53 »
Front and rear stopped working. Bottle full, no leaks I can see. Can hear pump working when operating switch. I'm thinking weak pump - any other ideas please?
Re: Washers in-op
« Reply #1 on: 25 January 2013, 12:03:33 »
Assuming the filter/grommet that the pump is pushed into is clean, then you have frozen pipes.  ;) ;)
http://www.omegaowners.com/forum/index.php?topic=90616.0
dazzle72
  • nottinghamshire
Re: Washers in-op
« Reply #2 on: 25 January 2013, 13:00:57 »
Thanks for the link - filter was clogged up. Fronts now work (poorly), back still in-op.
Re: Washers in-op
« Reply #3 on: 25 January 2013, 13:05:28 »
 :y  :y Could be frozen  ;)
Re: Washers in-op
« Reply #4 on: 25 January 2013, 13:06:17 »
Esp as its clearly had inadequate screenwash to kill off the white strigy stuff ;)
Re: Washers in-op
« Reply #5 on: 25 January 2013, 13:15:25 »
Almost certainly... I've noticed that the rear freezes even with the (virtually) neat screenwash I have in at the moment
