Author Topic: Auto Gearbox Service needed can anyone help?  (Read 1157 times)
brian36
  • Milton Keynes
  • 2.6 mv6
« on: 25 January 2013, 12:26:08 »
good day all, i am having some problems with auto box at present and not sure if filled properly etc,have foolwed checking proceedure but car over past while has felt a slip and uneven gear change. i have taken it to a couple places now but still not right and was wondering if any members out there that have taken gearboxes out and serviced etc? i live in fife scotland but happy to travel i have asked a member but waiting for reply as going down to nottingham i a couple weeks where car will be left for about a week and a ideal time to get looked at,can anyone advise please.many thanks :)
Re: Auto Gearbox Service needed can anyone help?
« Reply #1 on: 25 January 2013, 12:35:27 »
If its filled to right level, and is not showing electrical faults, probably best to replace box with a known good from a breaker.
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #2 on: 25 January 2013, 13:16:03 »
thanks the problem is i don't think checked properly for instance today garage after me showing them how to do sheet on checking atf they put car on ramp and undone the plug and out flowed the atf it was about 1/4 litre i then mentioned about how to do and they done plug up jacked car up drivers side undone plug but still come out so i mentioned about running car.so they done again with car running this time they put in about 1 litre and lowered car and a bit cam out not a lot then the done the plug up. but gear change still a bit of a slip. i reckon maybe gearbox needs service as it was going ok a short time ago and was told there was a leak from box and after checking when car lifted today it looks as if leak was from plug.there was a staining from plug rear wards. so problem is will this box be ok if dropped serviced and put back would this be a faster and cheaper option?
sorry if this sounds confusing buy my car diy sucks! reason why hoping to find a member competent enough to carry out this task
oh no gearbox faults showing other than spanner light comes on now and again normally after turning right when car at angle it clears after waiting a bit for it to decide to change gear
thanks
ps not sure if you got my message marks DTM caib
« Last Edit: 25 January 2013, 13:21:43 by brian36 »
