Author Topic: 3.0 ltr springs question.  (Read 2622 times)
ted_one
« on: 25 January 2013, 20:38:55 »
Think I'm going to change my rear springs and as usual could do with a bit of info/advice on wether I need standard rated springs or heavy duty. Car is a 2000 3.0 LTR ex police MV6  :y :y
Re: 3.0 ltr springs question.
« Reply #1 on: 25 January 2013, 20:41:05 »
Depends what you want ;)
ted_one
« Reply #2 on: 25 January 2013, 20:57:13 »
Point taken, not really a tear arse,although my licence will say different ::)would prefer the car to handle properly,I guess what I'm trying to bottom out, is the police spec car rear end beefed up i.e to carry all their equipment etc with heavy duty springs, and if so how much difference to the handling would standard springs make to the car. :-\
« Reply #3 on: 25 January 2013, 20:59:44 »
Many Plods have heavy duty springs.
I would say, to make Omegas really handle without sacificing ride, Irmscher springs are the way to go, although the 30mm less clearance is noticible  :-[
ted_one
« Reply #4 on: 25 January 2013, 21:04:46 »
Cheers for that Jamie.....just one other thought,standard shocks or gas? :-\ :y
« Reply #5 on: 25 January 2013, 21:08:17 »
I have only ever used GM, Irmscher and Bilstein B4 on my Omegas. All are traditional shocks
ted_one
« Reply #6 on: 25 January 2013, 21:12:42 »
Looks like some deep thought needed here,don't want to get it wrong.many thanks :y
« Reply #7 on: 25 January 2013, 21:13:46 »
Indeed, depends what you want from it :)
ted_one
« Reply #8 on: 25 January 2013, 21:34:33 »
Need the car to handle properly but not to the point of being bone jarring,so like I say it's only part of a plan and could wait for a few of months, perhaps until a meet where I could take a look at one or two cars that may have done something similar :-\
« Reply #9 on: 25 January 2013, 22:45:55 »
Depends what you want compared to how it handles now, with springs you have.
Why do you want to change the rear springs? ?...what is it about the rear end that makes want to change them?
Too hard? Too high? Too soft maybe?   Would loading the boot help?
ted_one
« Reply #10 on: 26 January 2013, 13:00:43 »
Possibly one of the springs is either weak or broken,as looking at the car from the rear it's listing a bit to one side :-\
« Reply #11 on: 26 January 2013, 19:34:48 »
Shock absorber can cause similar, but more intermittent if shock
pauls
  • By the sea minehead
    • Bmw x3
« Reply #12 on: 26 January 2013, 21:29:16 »
It could also be like mine when Daz changed them the left one was shorter than the other. :o
jb
  • bucks
    • 3.2 Elite
« Reply #13 on: 27 January 2013, 06:44:07 »
The original police spec spring has its own oart no which you can get from andy c.These spring deliver a rear ride height of 27.5 inches from the ground to wheel arch lip.
All after mkt hd springs will give you a higher rear ride height which looks bad and ruins the handling.
I have always replace police spec with the standard omega spring from BOGE and this retains std ride height and is prettymuch as firm as the GM oe spring.
ted_one
« Reply #14 on: 27 January 2013, 09:37:53 »
Thanks all for the info,I will certainly bear that in mind when I get around to dealing with the problem, got wishbones/track rods/drop links and steering idlers to do on two others first...starting Tuesday,glad the weathers improved :y
