Anyone near me good at welding
Started by TheBoy, 27 January 2013, 12:39:45
Just noticed I have a hole in the floor under the spare wheel, where its risted around the drain grommet  :-[
Hoping its not noticed by Mr MOTer tomorrow  :-[
Quote from: TheBoy on 27 January 2013, 12:39:45
Shouldn't be a fail, although it may be close :-\ Basically under 300mm from any seatbelt, suspension or chassis point is fail ;)
zirk
They will, but should be ok as its far enough away from a main structure point, or what ever their definition is.
I shall give him something obvious to fail it on, I'll knock the headlights up a tad ::)  (run out of knackered orange bulbs for the indicators ;D)
zirk
Quote from: TheBoy on 27 January 2013, 12:51:59
Hammer on the drivers side windscreen will do the trick.  ;)
Quote from: zirk on 27 January 2013, 12:58:10
He's yet to fail it on the rather great chip, about the size of a 50p, in the wiper arc ::)
Quote from: TheBoy on 27 January 2013, 13:14:53
Depends where in the arc ;) Anywhere other than driver's line of site and it's not a fail
If it had a rubber grommet, then technically the hole is pre existing part of the car, put there by the people who designed and built it ::)
Was a common issue on MK2 Granada saloons, but not an MoT problem unless you could put your hand through it ::) although, if the car was that rotten, there were several other panels to fix first ;D
Quote from: ex taxi al on 27 January 2013, 18:17:22
yes it is.. mine also have with no rust..
symes
Mate if it fails pop it over at weekend-soon do that for you PM if you need my number and address :y :y
Or alternatively, can easily sort that for you.  :y
Quote from: cem on 27 January 2013, 19:01:25
+ 2 but with rust  ::)
Matchless
Quote from: Marks DTM Calib on 28 January 2013, 09:25:16
I think Mark has some off-cuts from the buffer beam off the DMU....could tack a bit of that across the hole. :)
