Author Topic: Water Pump change?  (Read 1893 times)
Water Pump change?
« on: 27 January 2013, 23:45:00 »
Just read that the water pump on a V6 is run via the auxiliary belt so when getting the timing belt done on a V6 I assume I do not need to get the water pump done, which on a 4 put needs to be done. Is this right?....... :)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Water Pump change?
« Reply #1 on: 27 January 2013, 23:46:41 »
You don't have too Vamps but whilst there doing the cambelt its easy to change it  :y
If you decide to do it at a later date everything has to be stripped off again like doing the cambelt to do it again... if that makes sense
« Last Edit: 27 January 2013, 23:48:17 by Darth Loo-knee »
« Reply #2 on: 28 January 2013, 00:38:15 »
There have been a few issues with new water pumps failing early recently. Not sure if I'd change one on a V6 as a matter of course these days. :-\
I've had one (admittedly pattern) where the sealing rubber O ring perished after 2 weeks. Others have had genuine GM pumps fail after similarly short lifetimes. The original one from my car was still in fine fettle after 120k miles, so I certainly wouldn't bother until the next cam belt change at 160k if I had my time again.
« Reply #3 on: 28 January 2013, 00:39:20 »
Of course, if you're paying labour to change it it's more than an hour of your time wasted if it does then fail later... But the same could be said if the new one fails early.
steve6367
« Reply #4 on: 28 January 2013, 08:02:13 »
Kevin, is it driven by cam belt on 4 pot?
Steve
« Reply #5 on: 28 January 2013, 08:06:46 »
Steve
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #6 on: 28 January 2013, 09:39:22 »
Steve
Yes and needs replacing with the cam belt kit  :y
other rides
« Reply #7 on: 28 January 2013, 09:52:12 »
Agreed, on a 4 pot it forms one of the cam belt idlers so must be done with the belt.
We were talking about the V6 though. ;)
steve6367
« Reply #8 on: 31 January 2013, 17:32:23 »
Noted thank you - I am about to do mine.
Will add a water pump.
Steve
Page created in 0.021 seconds with 16 queries.
