Author Topic: Rear Shocks  (Read 2026 times)
stevenenglish
  • Essex
    • Omega 2.6cdx
Rear Shocks
« on: 28 January 2013, 09:41:23 »
Had recent MOT and advised that the OSR shock was starting to leak, also starting to creak when under load, can anyone advise what replacement is required, I do not know if they are gas or what so advice would be greatly appreciated. Car is 2.6 V6 CDX 52 plate. Also where can new ones be sourced, etc and if they can be DIY fitted. Many thanks.
Re: Rear Shocks
« Reply #1 on: 28 January 2013, 11:10:45 »
Saloon or estate :-\
Standard ones are cheap enough from Vx, self levelling ones are alot more and Vx only.
Easy to Diy if your happy with the spanners :y Only two bolts each side for the saloons ::) estates are a bit more involved, but straightforward enough :y
Hth, Al :y
Re: Rear Shocks
« Reply #2 on: 28 January 2013, 16:40:56 »
As CDX assuming no self levelling, so around £75 for pair of standard shocks from GM on trade. Try AndyC for these if you don't have access to trade club.
Dead easy on Saloon & Estate, just 2 bolts. Estate ones can be a pig to separate on bottom though!
Big_Al
Re: Rear Shocks
« Reply #3 on: 28 January 2013, 17:07:59 »
Again assuming non self levelling ,If anyone can confirm that  2.5 saloon shocks are the same as the 2.6
ones  . . .  I have a brand new pair of KYB ones that I got for my old S reg 2.5 elite
when I was going to convert from air shocks to standard.
Got the air shocks working ( faulty switch) so never fitted them .
You are welcome to come & collect & try them first  as I am also in Essex .
If they are the correct ones  . .  KYB No. is 343216                   £20 if you want to keep 'em
Re: Rear Shocks
« Reply #4 on: 28 January 2013, 17:11:31 »
Can't see why they would be different  :-\
stevenenglish
  • Essex
    • Omega 2.6cdx
Re: Rear Shocks
« Reply #5 on: 28 January 2013, 17:24:48 »
Essex big Al, many thanks am in Hullbridge on Wednesday afternoon, so could collect then, if ok with yourself. Saloon body and fairly certain that they are not self levelling, though not sure, 2.6 CDX model. Have set of spanners so if only two bolts that's great.
Many thanks to everyone for your help once again always good advice
Big_Al
Re: Rear Shocks
« Reply #6 on: 28 January 2013, 17:51:43 »
PM sent :y
Re: Rear Shocks
« Reply #7 on: 28 January 2013, 17:52:54 »
Make a note or take pics of the location/order of the various washers (rubber and metal) as they come off,as its easy to get it wrong when putting them back. :-[ ;) :D
Re: Rear Shocks
« Reply #8 on: 28 January 2013, 17:53:41 »
Been there myself  :-[  ;D
Michael2.6
  • Bishop Auckland
    • Vauxhall Omega
Re: Rear Shocks
« Reply #9 on: 28 January 2013, 18:16:05 »
I tried AndyC and the price was 100.68 and the Vat and plus postage for the pair and that was in August of last year?
Re: Rear Shocks
« Reply #10 on: 28 January 2013, 18:18:04 »
Was that TC or Trade? Been about 2 years since I bought them, must have jumped a bit then
Re: Rear Shocks
« Reply #11 on: 28 January 2013, 19:17:02 »
£50 each sounds about right ballpark for TC
Stallion
  • Romford
    • 3.2 Irmscher Elite
Re: Rear Shocks
« Reply #12 on: 29 January 2013, 20:27:41 »
+1  :y
