Wheel / tyre clarification needed ...........
Started by I_want_an_Omega, 28 January 2013, 18:29:41
I_want_an_Omega
Ok, I'm a bit confused and need a bit of clarification please chaps.
I'm looking at getting some spare steelies for the Mondeo and have noticed that the same size wheel appears to be fitted with different sized tyres on some cars:
16"  x 6.5 fitted with:
205 / 55 / R16
or
215 / 55 / R16
Is this correct, or have I missed something here?
Thanks
martin42
different spec cars use different widths, look in handbook or type in details into a tyre site and see what should be fitted :y
symes
Quote from: Lincs Robert on 28 January 2013, 18:29:41
205 / 55 / R16
or
215 / 55 / R16
Thanks
Width(mm)
Keith ABS
Only 10mm differance in width, so no problem on the same size rim.
keith B
I_want_an_Omega
Quote from: symes on 28 January 2013, 18:34:19
205 / 55 / R16
or
215 / 55 / R16
Thanks
Width(mm)
Yep, understand that - but thats the width of the tyre isn't it? The width of the wheel is 6.5" in each case - that's why i'm confused .......
Keith ABS
  Only 10mm. If it was 20mm then an extra half inch width on the rim.
Keith B
Broomies Mate
Its a measurement which starts from the rim, up the wall of the tyre, across the width of the tyre and then down the opposite wall to the rim again.
btc
215 tyre width 55 is 55% of tyre width is the sidewall and 16 inch wheel if that makes sense
rob in gib
Quote from: Broomies Mate on 28 January 2013, 18:49:34
Sorry but NO the 205/215 measurment is the section width of the tyre then the 55 is what percentage of the first figure the hight of the sidewall
Just chilling in the sun. I wish back in the rain like everybody else
