Author Topic: Omega air flap arm popping off motor  (Read 1901 times)
johnny_boy
  • hertfordshire
    • omega 2.0 gls auto v reg
« on: 29 January 2013, 13:55:18 »
Hi
No hot air in front woes...
As suggested i have have looked at the blend air flap arm and see if it is connected to the motor.
It isnt
I reconnected, but then when i tested it i switched controls to hot, motor started, arm started moving. It reached the end if its travel, the motor kept pulling and the arm popped off again.
Does anyone have an idea how to fix this?
Ta.
Drewomega
  • Aviemore and Mallorca
    • SKODA Octavia Scout 2.0
Re: Omega air flap arm popping off motor
« Reply #1 on: 30 January 2013, 08:45:50 »
I had exactly the same problem. My fix is still working ok.
http://www.omegaowners.com/forum/YaBB.pl?num=1303387561/0#0
I'm always last in the office in the morning but I make up for it by leaving first.
johnny_boy
  • hertfordshire
« Reply #2 on: 30 January 2013, 20:34:58 »
Genius.  :D :D :D
Proof that 'all things being equal, the simplest answer is the correct one'
johnny_boy
  • hertfordshire
« Reply #3 on: 03 February 2013, 16:20:52 »
The flat head pin through the drilled hole in the motor arm works. I have added a bit of gorilla glue on the pin to keep in there for good.
Thanks for the help.
Next, the passenger door lock and then the idle problem.
Gonna get this car back to where it should be.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #4 on: 04 February 2013, 08:59:02 »
whats this gorilla glue might be worth getting some
Drewomega
« Reply #5 on: 04 February 2013, 15:17:57 »
No problem! Never used gorilla glue though. ::)
