Author Topic: abs module  (Read 2466 times)
tidla
  • solihull
abs module
« on: 29 January 2013, 21:18:04 »
The day before i set out for a trip similar to tunnies, the abs, tc lights lit up briefly at slow speed, then went out.
No codes were stored.
One thousand six hundred miles later the lights are getting more regular along with no speedo reading. The old girl saved all the trouble till i got back and even started faultlessly at -15c (heated seats mmm)
The chances are its the module. Seen a picture posted which possibly showed corrosion damage.
Has anyone managed to fix/solder/ repair one or is it best to just send it off for recon?
(Even managed 30mpg overall trip fully loaded)
Re: abs module
« Reply #1 on: 29 January 2013, 21:24:17 »
There was a very long discussion of this some years back .. the end result being .. if memory serves me correctly, that the wire that "breaks" and needs reconnecting to the board requires an exceedingly specialised procedure and equipment that the average electronics expert will not have.
Simple soldering is impossible for several reasons .. one of them being the gunge the board is encased in.
Old site thread ...  :  http://www.omegaowners.com/forum/YaBB.pl?num=1265622074
I had mine refurbed by BBA Reman and was extremely pleased and happy with the result. £130 including a 2 year warranty - but that was 5 years ago now so check the price !!
http://www.bba-reman.com/uk/index.aspx
« Last Edit: 29 January 2013, 21:27:51 by Entwood »
Re: abs module
« Reply #2 on: 29 January 2013, 21:32:05 »
Yep, need to remove the gunge without damaging anything, then the wire needs welding back on, and under a microscope. Best leave it to BBA Reman or ECU_Testing, both of whom do a very quick service.
tidla
  • solihull
Re: abs module
« Reply #3 on: 29 January 2013, 21:54:08 »
Thanks for that, inquiry sent. Don't think a second hand unit will suffice as im on 97k myself.  :y
Re: abs module
« Reply #4 on: 30 January 2013, 00:18:54 »
If anyone can give me info on how to remove the "gunge",I may be able to have them repaired at work,as we have bonding equipment. :-\
Re: abs module
« Reply #5 on: 30 January 2013, 00:38:53 »
Only £90 incl postage  ;)
Re: abs module
« Reply #6 on: 30 January 2013, 01:12:58 »
It would be a lot less than that if I could get it done.I dont need one,but it could potentially be an OOF service. :y
Re: abs module
« Reply #7 on: 30 January 2013, 01:23:57 »
Just p*ss taking Albs ;)
Re: abs module
« Reply #8 on: 30 January 2013, 01:56:03 »
While Albs and I don't see eye to eye on a lot of things, what you can't fault him on is helpfulness, where he can. Why you feel the need to take the pee for that is beyond me, tbh. Uncalled for, its a common problem we could benefit from solving.
Re: abs module
« Reply #9 on: 30 January 2013, 02:15:16 »
I agree
Love & kisses Andy B::) ::) ::)
Re: abs module
« Reply #10 on: 30 January 2013, 13:59:41 »
Agree totally with Albs sentiments and the friendly piss take was between him & I as I knew he wouldn't take offence.  Chill out Pixie ;)
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
Re: abs module
« Reply #11 on: 03 February 2013, 00:48:49 »
bba do the repair through ebay as i had to have mine done, its cheaper then using their own site and now comes with a lifetime guarentee rather then the old 2yrs one, i got tools here to remove yours if need be
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
Re: abs module
« Reply #12 on: 04 February 2013, 09:04:45 »
If you have bondout kit then you would not need to remove the gunge (acetone is the likely solvent) as the needle bonding probes could be easily pushed through the clear goo to support the ultrasonic welding.
Its this same fault that affects the control modules on the Bosch VP injector pumps to.
