Author Topic: Omega headlight switch  (Read 2401 times)
kevin xf
  • Oxford
    • omega 3.2 elite
« on: 31 January 2013, 17:14:28 »
Hi all.   I fitted led fog bulbs about 6 months ago.  I'm now having problems with headlight switch.   When I turn my lights off my doors lock  :-\ !!!    Would fitting them bulbs overload the headlight switch ?  I also had to take the interior bulbs out as the over head interior light was staying on.
steve6367
Re: Omega headlight switch
« Reply #1 on: 31 January 2013, 17:28:04 »
LED would be lot less load than those they replaced - sometime not enough load can cause problems though.
Change back to the OEM and see what happens?
Steve
kevin xf
  • Oxford
    • omega 3.2 elite
« Reply #2 on: 31 January 2013, 17:42:05 »
Thanks Steve.  It's not been right since my mechanic left the door open causing the battery to go flat. He replaced battery with a spare he had as he killed mine.  Since then when I unlock the doors  and open drivers door the doors lock!!  It's now stopped doing that and know looking the doors when I turn the lights off.   I disconnected the power sounder would that have anything to do with it??    I replaced fogs with led cos it was cheaper to buy a pair of LEDs than1 standard  fog bulb  :-[
steve6367
« Reply #3 on: 31 January 2013, 17:47:57 »
The problems sounds more like water in a connection somewhere or maybe a poor earth?
Is it when you switch the LED fogs off? Or the main headlights?
Steve
kevin xf
  • Oxford
    • omega 3.2 elite
« Reply #4 on: 31 January 2013, 17:53:34 »
When I switch the main lights off.  Soon as the switch hits 0 the doors lock.
symes
  • oxford
    • R reg 940 volvo
« Reply #5 on: 31 January 2013, 19:55:35 »
Power sounder not to do with your problem mate-if mechanic left door open long enough to flatten battery that was a few hours mate probably door switch gone mate. or light switch TBH I would bet light switch--dont ask-numbnutz me did that lucky I got spares mate
kevin xf
  • Oxford
    • omega 3.2 elite
« Reply #6 on: 31 January 2013, 19:57:18 »
Thanks symes  :y
symes
  • oxford
    • R reg 940 volvo
« Reply #7 on: 31 January 2013, 20:04:06 »
Have door switch here in my pit workshop or just take one from spare mig for you if you want mate :y think I got light switch too but cant promise on finding it though mate :y you welcome to try-if it helps :y
kevin xf
  • Oxford
    • omega 3.2 elite
« Reply #8 on: 31 January 2013, 20:09:33 »
Ok mate will have a look on sat.  :y
symes
  • oxford
    • R reg 940 volvo
« Reply #9 on: 31 January 2013, 20:17:08 »
you might find my car in there ;D ;D ;D ;D its a f^^d
