Author Topic: Coolant level warning...but coolant full  (Read 2488 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 01 February 2013, 12:52:41 »
Hi guys, as above, topped up when warning came on but it's come back.
i take it the sensor is fubared. is that the electric connection under the expansion tank? does it just need cleaning or replacing?
cheers :)
RIP Paul Lovejoy
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: Coolant level warning...but coolant full
« Reply #1 on: 01 February 2013, 12:55:39 »
It maybe poss to clean the level float with some type of descaler but replacment tank prob the best bThey are not that expensive if i recall and they look nice as well. :y
Jaguar XJ6
Webby the Bear
  • Northampton
« Reply #2 on: 01 February 2013, 12:57:09 »
It maybe poss to clean the level float with some type of descaler but replacment tank prob the best bet.
i got a spare tank mate so thats cool ;)
so it would be nowt to do with the electrical connecter and would be the level thing inside the tank?
RIP Paul Lovejoy
ffcgary1
  • Mitcham,Surrey.
« Reply #3 on: 01 February 2013, 12:58:48 »
Yep the level float goes pear shaped after a period of time.
Jaguar XJ6
Webby the Bear
  • Northampton
« Reply #4 on: 01 February 2013, 13:00:01 »
sweet thanks mate. can i see it if i open the top?
RIP Paul Lovejoy
ffcgary1
  • Mitcham,Surrey.
« Reply #5 on: 01 February 2013, 13:05:05 »
Take the cap off and the float moves up and down the guide in the middle of the tank you cant get to it though.
Jaguar XJ6
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #6 on: 01 February 2013, 13:20:01 »
Check the concocter underneath tank, open circuit means empty, shorting the connecter = full.  ;)
Webby the Bear
  • Northampton
« Reply #7 on: 01 February 2013, 13:57:43 »
like the oil pressure switch ;)
got it! thanks guys.
RIP Paul Lovejoy
« Reply #8 on: 01 February 2013, 14:23:01 »
If there's a golf ball type thing bobbing around the tank, then the retaining washer has come away :y
If you can find the washer before it vanishes into the engine, then it can be repaired with a soldering iron :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #9 on: 01 February 2013, 15:35:45 »
Easiest way to do it is fit a new tank,as you cant buy the sensor,
 and makes engine bay look mmm lurvly. £40.00 on tc.
Hoof'land storeman.
« Reply #10 on: 01 February 2013, 16:23:09 »
Mine was only 18months old ::)
Webby the Bear
  • Northampton
« Reply #11 on: 01 February 2013, 16:41:15 »
its cool cos i pinched ralfs one before i scrapped him  8) 8)
RIP Paul Lovejoy
« Reply #12 on: 01 February 2013, 18:31:31 »
Ralf lives on  ;D Poke the ball up and down a bit , worked on my elite for a few months then another poke after that  ;)
Webby the Bear
  • Northampton
« Reply #13 on: 01 February 2013, 19:01:39 »
will do steve, cheers  :y
RIP Paul Lovejoy
Jukeboxnut
  • West Sussex
    • 2004 2.2 auto CDX estate
« Reply #14 on: 02 February 2013, 20:17:12 »
Mine packed up recently so I replaced the tank as recommended here which does make the engine bay look new again.  When I pulled out the electrical plug (tight fit) from the old tank I found that the flimsy glass reed switch had broken.  I bought a replacement for a few pence and soldered it on to keep as a spare in case it breaks again.  I would think that this is a common failure mode and am surprised it lasted for over 110,000 miles tbh.
