Author Topic: v6 missfires-possible cure  (Read 3623 times)
symes
  • oxford
    • R reg 940 volvo
« on: 02 February 2013, 10:03:03 »
as said-had missfire-erratic running NOT plugs+leads IT was my expansion tank=pipe from throttle body to header tank was blocked(inside header tank) - Unblocked header(must fit new one-when I find ir :D)
Miggy now runs sweet again :y :y :y
Re: v6 missfires-possible cure
« Reply #1 on: 02 February 2013, 10:34:12 »
Ooh... A bit of throttle icing! Uncommon in this country but does happen, as you have proven :y
  • Auckland
    • Mazda MPV
« Reply #2 on: 02 February 2013, 10:38:59 »
Weird. That pipe is there to stop ice forming in the throttle body.
I have had carburetor icing on old cars and motorbikes and it really screws up the running. I had assumed that the Omega would use the air flow meter to calculate the fuel requirement and wouldn't be so badly affected :-\ maybe at small throttle openings it uses the throttle position sensor but gets the fueling wrong because the throttle is bunged up with frost  :-\
[note to self] must type faster! [/note to self]
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #3 on: 02 February 2013, 13:23:19 »
hi guys,
sorry i'm confused as to what's happened here.
so the coolant pipe from expansion tank to throttle body was blocked not allowing coolant to the throttle (butterflies presumably?) and the butterflies froze???? therefore i suppos the throttle position would have been out compared to the air coming in read by the MAF.
I got that right? lol?
what was it blocked with symes?  :y
RIP Paul Lovejoy
« Reply #4 on: 02 February 2013, 13:42:37 »
hi guys,
To make it short and simple... Google the "Venturi Effect" for more information :y But...
The air, which is mist, accelerates as it passes through the restriction of the throttle bodies. This acceleration (change in pressure) also cools it dramatically and causes the moisture in the air to freeze. This frozen moisture restricts the movement of the throttle bodies :y
That's in very basic, layman's terms... Like I said, google as above or "Carb Icing" for more info :y
Webby the Bear
  • Northampton
« Reply #5 on: 02 February 2013, 13:45:45 »
hi guys,
nice one lazy. already done venturis in carbs at school  :y but ill check it out  :y
RIP Paul Lovejoy
« Reply #6 on: 02 February 2013, 13:48:10 »
hi guys,
So they should have taught you about the cooling of air and the potential for carb icing ;)
To help a little more... Many Light Aircraft still use carbs so carb icing is a real threat for them so you might find a little more detailed information on an aviation site ;)
Webby the Bear
  • Northampton
« Reply #7 on: 02 February 2013, 13:58:58 »
hi guys,
nice one  :y ill 'ave a butchers  :y
RIP Paul Lovejoy
« Reply #8 on: 02 February 2013, 14:00:31 »
Should add, the reason throttle icing is rare is because you don't have the additional temperature reduction caused by the vaporisation of the fuel, which is quite marked :y
symes
  • oxford
    • R reg 940 volvo
« Reply #9 on: 02 February 2013, 21:39:07 »
Dont know about ice freezing it up but honestly miggy was running sick this morning and when I cleared that blockage-ran sweet again ??? ??? Reckon my miggy got mind of its own :o
  • Auckland
    • Mazda MPV
« Reply #10 on: 02 February 2013, 21:54:50 »
Carburettor icing is only rare if you don't have carburettors and only drive on warm sunny days >:(
On both my series III Land Rover & my old V8 Range Rover I had fit a means of heating the carburettors in cool/damp weather :( :(
Unleaded petrol seems to be much worse for icing than original full fat 4 star  :-\
Nearly all cars (produced in the last 40 rears)  have had either a thermostatic air intake or a water heated throttle body to prevent icing. Kawasaki had to recall some of their motorbikes & fit electric carburettor heaters when unleaded fuel became common.
« Reply #11 on: 02 February 2013, 22:21:14 »
True... But then there are very few (if any) modern cars that have carbs ;)
symes
  • oxford
    • R reg 940 volvo
« Reply #12 on: 02 February 2013, 22:25:24 »
I know mate-as said weird cause/effect though-
« Reply #13 on: 02 February 2013, 22:27:56 »
Drove my Omega today,and it definitely had a misfire and a lack of power on LPG at around 2k rpm.Switched to petrol and it was fine.
Might try changing plug leads as I have a spare set.If that doesnt work, my recently replaced dispack "thought to be a good one but not certain",may be suspect. Other than that - LPG system problem I suppose. :-\
« Reply #14 on: 02 February 2013, 22:42:59 »
Aye , my old Gpz 750 suffered icing but later model got the carb heaters  >:(
Page created in 0.03 seconds with 16 queries.
