Author Topic: Steering idler  (Read 2930 times)
MV6Danny
  • Swindon, Wiltshire
  • Driving at the speed of light
    • 99 irmscher mv6 3l Manual
Steering idler
« on: 02 February 2013, 16:13:29 »
Hi guys. I am a bit P***ed off. I bought a new steering idler from the bay and fitted it. Took the car all the way to wheels in motion to get the geometry done only to be told that the idler is loose. The guy showed me the play in it and it was loads. Could this be the mount that the idler sits on that has gone or do you think it could be a faulty idler? Is this a fault that is common on the omega? Hope somebody can help with this as am really p***ed now. Traveled all that way for nothing :'(
Back in the MV6 again now
Re: Steering idler
« Reply #1 on: 02 February 2013, 16:16:49 »
« Last Edit: 02 February 2013, 16:20:02 by RobG »
MV6Danny
Re: Steering idler
« Reply #2 on: 02 February 2013, 16:24:00 »
didnt buy genuine. Will that make much difference then?
Re: Steering idler
« Reply #3 on: 02 February 2013, 16:25:31 »
May`s well have fitted a Mars bar then. Well documented here that aftermarket idler arms are unadulterated shite
MV6Danny
Re: Steering idler
« Reply #4 on: 02 February 2013, 16:26:56 »
I'll send it back then. Says it has a 12 month warranty on it.
Re: Steering idler
« Reply #5 on: 02 February 2013, 16:29:59 »
Bay link or from here (Jason) http://www.allgermanparts.co.uk
MV6Danny
Re: Steering idler
« Reply #6 on: 02 February 2013, 16:34:11 »
I bought this one http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=330855263355#rpdId
I will get it from http://www.allgermanparts.co.uk/ or the other ebay link in previous post.
Could it be the mounting that the arm slides over causing this or not?
Re: Steering idler
« Reply #7 on: 02 February 2013, 18:50:15 »
You won't know until you fit the "correct" oe idler.  Unlikely though  ;)
MV6Danny
Re: Steering idler
« Reply #8 on: 02 February 2013, 18:57:20 »
hopefully its not gone as wouldnt know where to get one from. I have ordered another idler now. all german parts are out of stock so got it from the bay on the link above.  :y
Re: Steering idler
« Reply #9 on: 03 February 2013, 01:35:48 »
If its a pattern idler, that will be the failure, more than likely.
Never heard of the bracket failing, but there's always a first time. I suppose.
car5car
  • Florida USA
    • 01 Cadillac Catera
Re: Steering idler
« Reply #10 on: 03 February 2013, 05:40:58 »
I had free play between inner sleeve and axle. If idler arm axle is worn out, you can buy 100 arms from different manufacturers and get mad at them. I used JB Weld (epoxy), problem solved, but I was told it was wrong.:)
01 CADILLAC CATERA 3.0 engine (Omega)
MV6Danny
Re: Steering idler
« Reply #11 on: 05 February 2013, 02:06:00 »
What is that and what did you do? Also where do you get it from? Thanks  :y
car5car
  • Florida USA
Re: Steering idler
« Reply #12 on: 05 February 2013, 03:23:48 »
I used Kwik Weld.
http://www.jbweld.com/
You need to find out where free play is. Most likely I had worn out idler arm axle.
Free play can be between 2 parts: arm/outer sleeve/rubber/inner sleeve/axle.
