Author Topic: Pug 107 Clutch  (Read 3528 times)
John-R
  • Liverpool
    • 2003 2.6 V6 CD
Pug 107 Clutch
« on: 02 February 2013, 16:27:31 »
Anyone had any experience of the Pug107 and apparently "known" clutch issues ?
Mine's got 35,000 miles and showing signs - stiff changing especially 1st to 2nd.
Read about other owners who've had them go at 6,000 miles !!! Later models fitted with a larger 190mm plate which apparently does the job. Would expect a "city car" to have a clutch that's up to the job and lasts a lot more than 35,000.
Still under a 12 month used car warranty so have to see what they say.
You can pick your friends and you can pick your nose . . but you can't pick your friends nose !
Re: Pug 107 Clutch
« Reply #1 on: 02 February 2013, 16:39:25 »
Clutch won't be covered as it's a wear item :'(
Try taking it back and demand your money back as it isn't fit for purpose...
Though having said that, if it lives in town, the clutch is going to take a kicking whatever it's fitted to :-\
tidla
  • solihull
Re: Pug 107 Clutch
« Reply #2 on: 02 February 2013, 19:14:12 »
Depends on the previous owner.I have seen an elderly deaf driver smoke a clutch just going around the shops and be totally oblivious to the smoke and smell.
If its just stiff it might be worth a look at the linkages to the box first and possibly replace the cable first.
Re: Pug 107 Clutch
« Reply #3 on: 02 February 2013, 22:55:16 »
+ 1  :y
Re: Pug 107 Clutch
« Reply #4 on: 03 February 2013, 02:08:03 »
+ 1  :y
+2..... :y
Re: Pug 107 Clutch
« Reply #5 on: 03 February 2013, 07:46:29 »
If it's owt like the 106 clutch, you can only adjust the cable so far before the clutch fails :-\ once it's on it's way out there isn't much stopping it :'(
Not surprised their crap if they're only 190mm diameter though :o
Re: Pug 107 Clutch
« Reply #6 on: 03 February 2013, 17:39:35 »
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Pug 107 Clutch
« Reply #7 on: 04 February 2013, 18:05:24 »
Don't worry Steve,cheap to buy and easy to fit ;)
other rides
Re: Pug 107 Clutch
« Reply #8 on: 04 February 2013, 18:17:58 »
Looking at the gear linkage , its all rusty and worn .. looks like the original linkage . Going to replace the linkage in the better weather . Do these linkages just prise/pop off  :-\
henryd
  • west cornwall
Re: Pug 107 Clutch
« Reply #9 on: 04 February 2013, 18:30:39 »
Yes,the little rods just pop off,normally easily when they are knackered :y
other rides
Re: Pug 107 Clutch
« Reply #10 on: 04 February 2013, 18:34:49 »
Excellent , best do it sooner than later before it falls off  ;)
