a tyre discussion ..
Started by cem_devecioglu, 03 February 2013, 15:48:55
as a thread involving half a day of my efforts been deleted,
I think its necessary for other members to read this technical discussion.
if you prefer to delete also this one , then feel free to delete my membership >:(
cem:
ANY OBSERVATION WITHOUT MEASUREMENT IS NOTHING..
also a test without measurement is not a test.. but when you start to measure now we can start talking..
Lazydocker:
Because, in your own words, you are an engineer
Cem:
Here are some definitions and questions explaining why I said that..
The word measurement is derived from the Greek word "metron," which means a limited proportion
Why do we measure ?
In science, measurement is the process of estimating or determining the
magnitude of a quantity, such as length or mass, relative to a unit of measurement,
such as a meter or a kilogram.The term measurement can also be used to refer to a
specific result obtained from the measurement process.
for science we need standardization, we revere precision, and we aspire for control. The very
ancient and dominant belief of Western culture is that numbers are what is real.
If you can number it, you make it real. Once made real, it's yours to manage and control.
We depend on numbers to know how we are doing for virtually everything.
It is numbers and only numbers that define and make visible what is real.
This is the "hard stuff," the real world of management- graphs, charts, indices, ratios.
Everyone knows that "you can only manage what you can measure.
Lazydocker:
So you cannot accept different weights mean different performance? Why?
As an engineer you must know that momentum is related to the mass in motion.
Therefore a 1000Kg car cannot possibly have the same momentum as a 2000Kg car
travelling at the same speed That additional momentum (and mass) can and does
make a huge difference to how a tyre will perform
Cem:
tyre performance is barely the grip between the road and tyre which is a function of friction
coefficient changing from tyre to tyre that you try to compare with tests..
if friction coefficient is 0 there will be no grip at all..
momentum has nothing to do with friction  between your tyre and road.
momentum is mass * velocity, so kg * m/s
friction coefficient is dimensionless either kinetic or static..
friction force is kg * m/s2
so apples and pears really..
Cem:
most of daily passenger cars start around 1000 kg and go upwards .. most using MacPherson
type struts and there is no hocus pocus in this area..  so whatever your cars weight is,
the results although changing in magnitude , the relative measurement test orders will never change totally..
Lazydocker:
most of daily passenger cars start around 1000 kg and go upwards .. most using MacPherson type
struts and there is no hocus pocus in this area..  so whatever your cars weight is, the results
Actually, a lot of "premium" cars are now using double wishbone set up instead of MacPhearson
struts because MacPhearson Strut set up is flawed and poor performing in a heavy car...
So even if tyre tests were done on a large premium car they would still only have limited relevance
Cem:
now to simplify the picture take any of the tests alone (because they are a combination of
different tests) ,braking ,lateral grip or road resistance .. it varies from tyre to tyre by
friction coefficient difference in any case..although tyres dont behave like a brick it doesnt
change the result because you measure the already effected final coefficient of friction.
and different tyres will sort themselves within the test relational to their friction
coefficients..the only problem here is that tyre producers.. will they keep their expensive
compound and structure with increasing sizes or not ? unfortunately answer wont be yes all the time..
from wikipoedia
"The double wishbone suspension was introduced in the 1930s. French carmaker Citroën used it since 1934
in their Rosalie and Traction Avant models. Packard Motor Car Company of Detroit, Michigan used it on the
Packard One-Twenty from 1935. and advertised it as a safety feature. Prior to the dominance of front
wheel drive in the 1980s, many everyday cars used double wishbone front-suspension systems,
or a variation on it. Since that time, the MacPherson strut has become almost ubiquitous, as it
is simpler and cheaper to manufacture. In most cases, a MacPherson strut requires less space to
engineer into a chassis design, and in front-wheel-drive layouts, can allow for more room in the
engine bay. A good example of this is observed in the Honda Civic, which changed its front-suspension
design from a double wishbone to a MacPherson strut after the year 2000 model.Double wishbones are usually
considered to have superior dynamic characteristics as well as load-handling capabilities, and are still
found on higher performance vehicles. Examples of makes in which double wishbones can be found
include Alfa Romeo, Honda and Mercedes-Benz. Short long arms suspension, a type of double wishbone
suspension, is very common on front suspensions for medium-to-large cars such as the Honda Accord
(replaced by MacPherson struts in 2013+ models), Peugeot 407, or Mazda 6/Atenza, and is very common
on sports cars and racing cars.It also provide least camber change at bump and rebound condition."
its not new.. as said because of space and cost limitations its not commonly preferred.
we are talking about omegas which have standard macpherson struts.. where many other cars use the same..
all tyre test makers note which car they used in tests so you can be aware if you want to omit.
However I dont change my opinion and I still think test results meaningful as they
test all tyres in the same double wishbone.. so test order wont change and results are still relevant ..
Lazydocker:
Additionally, the tyre Tests you keep quoting are paid for by the premium tyre manufacturers
so they wouldn't be published if they didn't agree with them
Cem:
not all tests are done by producers..  there are indenpendant test organization like
TUV ..
Cem:
if you expect a bottom n th order tyre to be at the top of list you will wait forever..
Lazydocker:
On that we agree... But just because a tyre is at the top of the lists doesn't
make it suitable and good for the Omega..
Cem:
how you conclude that ? omega is just an ordinary big car with 4 wheels.
what makes it different ? does it have a special set up.. does it fly ?
a top of the list tyre will make a a basis for comparison.. if you prefer to buy the n th tyre,
its your option ..
Lazydocker:
Taken from your same test quoted above:
28th: Maxxis MA Z1 Victra
Total: 88.7 / Dry: 40.2 / Wet: 48.5
I binned a pair of brand new tyres of this brand (3000 miles) because they were truly awful
on the Omega... I replaced them with a "Budget tyre" that performed better in every way... FACT
Cem:
You dont mention what brand tyre you replaced with so we have no way of comparing..
Lazdocker:
But that "Ranking" is a load of 'dangle berries' anyway... It's just the dry and wet distances
added together yet the winner has a higher differential than others lower down the list
Cem:
You dont have to follow/accept the test conclusion.. you compare the measurements as its given
and you decide yourself.. I have seen also rubbish decisions that test maker magazines give
different weight ratios to different test results.. Thats the point where your decision comes
into account.. YOu look in values than decide..
Lazydocker :
anything can be proven or dis-proven if you look hard enough for the answers you want
Cem:
No.. a tyre measured to be stopping at 35 meters is always better (with respect to braking) than the tyre stopping at 36 meters..
it can never be disproved unless you make a mistake or a hoax in the test..
Lazydocker:
What I can't understand is the arrogance you display in not accepting that different
cars behave differently with the same tyres
Cem:
You didnt define different behaviour..
Let us try to define.. What do you expect from a tyre
* to stop (braking) (measurable and comparable)
* to accelerate (measurable and comparable)
* to turn curves (lateral g) (measurable and comparable)
* being comfortable - strict evidence prooved that if you want performance
you have to compromise comfort or the reverse and there are alternative tyres with
different combinations..  which way you will go is up to you..
and that parameter is a bit personal and not easily measurable imo..
Lazydocker:
Anyway... This was supposed to be a thread discussing the merits of All Weather tyres
as a compromise in this country and your linked test has compared at least one M+S rated tyre (the Enduro)
against premium summer sport tyres... What's the point in that
Cem:
The goal weas to compare its performance.. and brake distances shows its not a good tyre (to me at least)
I said my piece on the last thread. I shall say no more on the subject until we have conducted a test using real tyres on real Omegas :-X
Quote from: ex taxi al on 03 February 2013, 16:02:45
I think the discussion outlines how a test must be done..
But a tyre is just a tyre?  ::)  :D
Quote from: tunnie on 03 February 2013, 16:08:39
yeah .. true from some point of view ;D :y
Not sure if I missed something but I thought that, certainly the recent discussions between Cem and I, had been kept polite :-\ I certainly didn't take offence and I hope he didn't ???
Anyway... So be it! I don't want to kick off another one ::)
Look at it this way Cem... It was great practice writing ;D ;D
Quote from: Lazydocker on 03 February 2013, 16:11:13
nope.. no reason to feel offence.. :y
Quote from: cem on 03 February 2013, 16:13:09
:y :y
there were other discussions thats lost because I didnt back up..
eh.. this is a lesson.. next time I'll back up whole thread.. :(
Original thread removed because it was unproductive, and to my reading, getting personal, and the behaviour of some/most of the participants I felt was inappropriate.
This one is being locked now, for deletion in a few hours, for exactly the same reasons, it will only go one way.
Any problem with that, feel free to PM me.
