LPG kit
Started by omega3000, 06 February 2013, 09:46:42
Pipework, tank, fixings, filler, filters... Basically all that contains is the ECU and loom, reducer and injectors ;)
Nowhere near a complete kit and the reducer isn't man enough for an Omega ;)
As LD says, basic loom kit & doesn't have piggyback connectors also the Reducer is a Tomasetto Alaska which is only good for 140HP max. so ok for a Desmond but not for the Full Fat Omega!
How do I know this? Because I have just bought the same kit from another supplier after trying countless times to contact the usual OOF supplier who is more elusive than the Scarlet Pimpernel! :'(
Having a 140bhp rated reducer on the 2.2, if doing again I would get one more go, its not really enough.
Ratings on things like vapourisers are always going to be theoretical and, probably, with a pinch of BS added for good measure. I would say a 140BHP rated one would probably be no use for any Omega engine if you intend to run it on LPG over the full rev range.
Quote from: Kevin Wood on 06 February 2013, 15:46:40
Full tank it can cope with occasional 5k+ rpm, but if you drive using whole rev range all of the time I fully agree its not up to the job.
I rarely rev above 4k in the 2.2, so its not really a problem  :)
Quote from: tunnie on 06 February 2013, 15:49:13
Yours struggled when we calibrated it to be fair ;)
But that engine revs to almost 7k, and thats where the power is. Why wouldn't you use it  :-\
Ah, its tunnie. 'Nuf said.
Quote from: TheBoy on 06 February 2013, 18:49:02
Yes have you SEEN who you talking to? ;)
Same reason he doesn't need poly.
When the 3.2 gets LPG, thats going to get done right....
