Flywheels... DMF v Normal
Started by P6UL K, 06 February 2013, 12:16:35
serek
vectra B 2.5 or 2.6 V from 95-2002 flywheel are same only differents is
vectra 2.6 use 240mm clutch plate thats all
P6UL K
Quote from: cem on 06 February 2013, 22:15:23
here
before
I don't suppose you have any pictures of the otherside of the flywheel showing the GM part number?
Quote from: P6UL K on 08 February 2013, 15:29:53
here
before
its in home.. will check.. :y
here.. but unfortunately numbers not meaningful.. that was the only one..
P6UL K
tidla
I know that LUK do a line of ready made conversion kits for common applications.
Crappy dmfs, Changed a few but never had to cut access to the bolts before.
Dieseasel golf.
P6UL K
Just bought this FLYWHEEL, lets hope its the right one!!
Mind you, no great shakes if not as it was only cheap.
