Stupid Trim
Started by omega3000, 06 February 2013, 21:54:13
Ive got trim flapping on drivers door  ::) Its not damaged just loose , ive tried superglue , tried proper trim double sided tape and its still not stuck . I know that silkaflex or tigerseal does it but dont want to buy a full tube of it for a thimble full . Any idea what i could use instead  :)
symes
How about hotglue gun?
MV6Matt
Quote from: symes on 06 February 2013, 21:55:23
+1
The reforming of the plastic can help take the 'set' out of the shape
(thanks Ian)
Yeah i would try that but no glue gun  :-[ Mite have to bite the bullet and buy the tiger seal , only other reason i dont want to buy it is that half the tube went off hard last time i bought that  :( Because im trying to stick hard plastic to metal there mite not be any other solution .
martin42
get some proper trim clips on it,wont cost much or pop down the breakers and nick some :)
Webby the Bear
i have glue gun mate. can bring up on sunday with heat gun if you need? :)
RIP Paul Lovejoy
Quote from: martin42 on 06 February 2013, 22:10:13
Its bust where the clip fixes to , right on the inside end where its really needed martin so it has to be glued mate  ;)
Araldite  :-\ :-\ :-\
Quote from: Webby the Bear on 06 February 2013, 22:10:53
We could try that mate , symes cant make it but think martin mite be over all being well  :-\
Webby the Bear
Quote from: EMD on 06 February 2013, 22:18:40
just let me know whats happening boys ;)
RIP Paul Lovejoy
Cant see hot melt glue working.
When you tried the trim double sided tape did you
1) clean the surfaces and de-grease them fully
2) warm the area up well with a hair dryer.
Quote from: Webby the Bear on 06 February 2013, 22:30:59
Pm's sent to all as snow and rain forecast weekend  >:( >:( >:(
Anyway this trim  ::) Last resort , i used some silicone to fill out the void the some polypipe glue on the edges  :-X ite being held down overnight with gaffa tape ... so see how it goes  ;D
Quote from: Marks DTM Calib on 07 February 2013, 15:23:00
1) clean the surfaces and de-grease them fully /  yep  :y
2) warm the area up well with a hair dryer. / nope  :(
Trouble is the hollow on the back of the trim needed to be packed out so ive filled with silicone , if it dont work i will get tube of tiger seal , then it will never come off  8)
symes
Mate can make 16/17th if you can wait 1 week will bring an industrial hot glue gun( £100) Believe me mate that will do it-it uses 14mm glue sticks-I used it to refit trim on back of miggy seats and carpet on Spare tire lid :y :y
Quote from: symes on 07 February 2013, 20:49:02
Thanks symes , will see how this fix has gone , held it in place with gafa tape while the glue and silicone goes off  8)
P.s please dont bring the V8 or ill be having sleepless nights for years  :'( ;D
symes
Quote from: EMD on 07 February 2013, 21:02:31
yes mate you would'nt want tis outside your house eh
Quote from: symes on 07 February 2013, 21:26:59
Cant say i would be back after a test drive for some time  ::) Just dont knock your mirrors off on the gate post like i did  ::) :-[ ;D
