Warning for Hillpers boot mod.
Started by megaomega123, 08 February 2013, 17:54:48
Quote from: JamesV6CDX on 08 February 2013, 19:21:17
Quote from: v6man54deg              Geffd on 08 February 2013, 19:16:12
whats the boot mod?
I think it lets you open the boot with the keys in the ignition?
I never bothered with it, by many find it useful..
Later ones had it fixed with pressing and holding  :y
megaomega123
Quote from: tunnie on 08 February 2013, 19:21:26
whats the boot mod?
http://www.omegaowners.com/forum/index.php?topic=90516.0
Early facelifts had to have key removed to pop boot.
Mine is also a 2000 year with mod, never had a problem
Have you ever had a key reprogrammed with the alarm triggered?
v6man54deg              Geffd
Cheers mine is like that - bit of a pain having to remove the key if you are opening the boot for a passenger
V6 problems solved : Worked at the V6 Engine plant for 13 years on durability testing and warranty issues, this job included many trips to Russelsheim, Trollhattan, Michigan, Atlanta,keiserslaughtern.
There are a fair few different ATWS ECUs fitted to facelifts, not just the 2 (early/late) we assume.
Wonder if it only affects some types  :-\
Quote from: tunnie on 08 February 2013, 18:47:44
I've got hillpers boot mod on the 2.2, cut the wire myself. Had new key programmed via tech2 about a month or so ago, no issues.
Did we do that? Can't remember  :-[
I remember you scrabbling around for the carpass, and I remember soldering in some switches into one of your fobs (don't ask me which car).
Its that Albs bloke, he's infected me with Albshiemers ;D
Quote from: TheBoy on 09 February 2013, 08:43:13
Yup, I remember taking drivers kick panel off  :)
Quote from: tunnie on 09 February 2013, 08:46:09
I know you have the boot mod, with that annoying interior light problem (thats really annoying).
I was asking if we did the key, as I really can't recall doing it  :-[
Did I mention the boot mod is *really* annoying?
Yeah we did a key, few weeks before I went to Austria. Done on the road outside Tunnie Towers, think your rusty bullet was in  our garage for some reason? Think we decided to loose some sockets in your engine  ;D ;D ;D
Don't really interior light issue, what does really annoy me is the 3.2's tapping  ::)
SMD
I refrained from doing the boot mod on mine because of the interior light side effect. Is there a way around it?
Quote from: SMD on 09 February 2013, 09:11:32
Yes
Quote from: tunnie on 09 February 2013, 09:01:17
I really don't remember ;D
I remember the subsequent curry.
Not found any sockets yet
SMD
Quote from: TheBoy on 09 February 2013, 11:03:45
Yes
Is it as easy as the mod itself?
Quote from: SMD on 09 February 2013, 11:27:39
Yes
No
There is more than one way to do it. I'll post up options when I can see through the snot fest
