Author Topic: Cruise upgrade - hidden cost.  (Read 7080 times)
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« on: 27 October 2006, 20:24:25 »
Recently upgraded to Cruise & had Tech2 done to enable system but VX want either £13 or £20 + VAT to supply cluch switch to get it to work.
Difference in price apparantly due to switch being Chassis specific - robbers!
Chopsdad
  • Keep it clean!
Re: Cruise upgrade - hidden cost.
« Reply #1 on: 27 October 2006, 20:28:33 »
Sorry guys - wrong section.
Tonight's moderator might want to move to General Chat - or bin.  You choose.
Taxi_Driver
« Reply #2 on: 28 October 2006, 08:16:01 »
If thats for them to fit it as well......sounds ok to me.....even with the difference in price for the different switch.......suprised they didnt say £45 for tech2 work and another £45 to fit the switch as well on top of the cost of the part!
« Last Edit: 28 October 2006, 08:18:25 by Taxi_Driver »
Chopsdad
  • Keep it clean!
« Reply #3 on: 28 October 2006, 11:54:48 »
Just been this morning & need the £20 switch (supply only) - but as the nice mechanic refused the bung for enabling the system it doesn't seem so bad.
« Reply #4 on: 28 October 2006, 12:22:49 »
take it your is a manual? I'll have to check but i think i have a spare clutch switch... i ordered it when i bought some other bits, but turned out my car already had one.
Its yours for a £5 posted if u want it?
Essex_Andy
  • Have a guess?
« Reply #5 on: 28 October 2006, 22:41:39 »
Apart from clutch switch and the stem/stalk what else is needed before you can get the setup enabled?
If an artic overtakes you, you're driving too slow!!!!!!!!!!!
Chopsdad
  • Keep it clean!
« Reply #6 on: 28 October 2006, 22:43:12 »
Thanks Tunnie I'll PM my details.
« Reply #7 on: 28 October 2006, 22:46:24 »
If its drive by wire (2.2,2.6,3.2) then it also needs 30 seconds with a tech2 as well as stalk and clutch switch if manual (some manuals already have clutch switch)
Older engines need actuator/ecu, cable, stalk, brake switch (4 pin one), and clutch switch if manual. No tech2 work reqd.
Chopsdad
  • Keep it clean!
« Reply #8 on: 28 October 2006, 22:49:37 »
If your car is fly by wire thats it - check this out first.  If FBW then just swap the stalk & connect the additional fly lead to your pre wired loom behind the steering shroud.  Ask nice man with Tech2 to enable instrument software & you're off.  Apparantly its 50/50 as to whether you have a clutch switch already.
Key search under cruise upgrade as there are many threads that may help.
Good luck
Essex_Andy
  • Have a guess?
« Reply #9 on: 28 October 2006, 22:50:53 »
So for a mini-facelift 1998 2.5 cd its not just a case of clutch switch, stalk and cable to throttle?
Chopsdad
  • Keep it clean!
« Reply #10 on: 28 October 2006, 22:53:41 »
I'll let The Boy confirm but sadly I'd say not. :(
« Reply #11 on: 28 October 2006, 22:59:56 »
ecu/actuator, cable, stalk, brake switch and clutch switch if manual. About £40 from scrappy. Plug it in and go :)
Essex_Andy
  • Have a guess?
« Reply #12 on: 28 October 2006, 23:09:58 »
daft question but what and where is the ecu/actuator? Any pics?
« Reply #13 on: 29 October 2006, 09:55:51 »
bolted to inner wing.
it contains the ecu controller, and a stepper motor to pull a 2nd throttle cable.
Plugs into the 10 pin connector clipped to top of drivers side suspension turret.
« Last Edit: 29 October 2006, 09:56:28 by TheBoy »
Essex_Andy
  • Have a guess?
« Reply #14 on: 29 October 2006, 11:32:37 »
Thanks :y
Right had a look under the bonnet
No sign of a connector for the ecu thingy to plug to....will be under the black scuttle thing?
Also in the boot of my car theres a two pin multiconnector on the near side tucked up high...what would this work normally...my car doesnt have a blind
« Last Edit: 29 October 2006, 14:00:28 by Essex_Andy »
