merc sprinter ?
Started by raywilb, 09 February 2013, 13:26:15
raywilb
indicators on a merc sprinter has suddenly stopped working. if its not a fuse my guess its a switch/relay problem. does anybody know where these are situated.?. thankyou in advance.
martin42
Panel on drivers side seat frame,relays and fuses are there iirc :y
Quote from: raywilb on 09 February 2013, 13:26:15
Probably a question best asked here ..... http://forums.mercedesclub.org.uk/
I'm not trying to be a clever bugger, but after the short time of owning a Merc, I've discovered that there are some weird & wonderful ways of making you return to a dealer or at best a good independent. eg the indicator flashers on her Smart are controlled via a relay built into the SAM (Signal Acquisition Module) which is also where the main ECU lives ..... My R Class has two of the buggers. And ISTR that someone on the MB forum asked about lack of flashers on his A/B/C/S/?/whatever Class and it was part of some mega expensive box of MB electrickery.
But as you say it could just be a fuse  ;D
Quote from: Andy B on 09 February 2013, 21:34:39
Don't hold back with the truth will you Andy......... :D :D :D
Quote from: Vamps on 09 February 2013, 21:41:35
As you might have noticed, I've never been one to sit on the garden fence ........  ::) ::) ::)
Quote from: Andy B on 09 February 2013, 21:53:45
I think OP was expecting a £ x couple for a flasher unit....... :D :D
raywilb
Quote from: martin42 on 09 February 2013, 16:41:44
thanks , the guy that owns it rang me to ask if I knew. a common fault with sprinters I,m led to believe.  one thing I did read was blown fuses & relays could be caused by the bolts that fix the fuse box housing being too tight. slacken them off a bit & problem may cease. the logic of it wasn,t explained :-\
