Author Topic: Sealey 24V Cordless Impact Wrench  (Read 4096 times)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« on: 11 February 2013, 22:38:58 »
Though I'd really like a Snap-On jobbie, I'm seriously tempted by this offer:
It wouldn't see 'everyday' use, so thought that it'd be a worthy alternative.
Anyone got/had experiences with similar?
Discuss ...  :-\
Re: Sealey 24V Cordless Impact Wrench
« Reply #1 on: 11 February 2013, 22:45:47 »
Can you adjust the torque setting Seth or is it just FT?  :-\
Seth
« Reply #2 on: 11 February 2013, 22:50:40 »
Oooh ... good point Tig.
Spec just states the max torque figure - no mention of 'adjustability' ???
« Reply #3 on: 11 February 2013, 22:50:48 »
Looks like FT to me ...
http://www.motorsport-tools.com/sealey-cordless-impact-wrench-24v-12sq-drive-410lbft-cp2450-p-267680.html
but I've downloaded the instruction book ...
Edit .. no mention of torque setting in the manual .. so assume its fixed torque only .. :(
Further edit .. this one has 6 settings but is more expensive ...
http://www.motorsport-tools.com/sealey-cordless-impact-wrench-192v-12sq-drive-super-torque-control-400lbft-cp3004-p-267682.html
« Last Edit: 11 February 2013, 22:56:49 by Entwood »
« Reply #4 on: 11 February 2013, 22:56:49 »
When I said FT, I didn't mean Fixed Torque.....  or Financial Times for that matter!!  ;D
Seth
« Reply #5 on: 11 February 2013, 23:00:06 »
Yeah Nige - just read the same meself, though Sealey's helpline is shown.
Might be worth a call tomorrow.
« Reply #6 on: 11 February 2013, 23:00:47 »
TB has one I think.
I have a small hitachi, only does up to 70-80 nm, and undoes about 100nm. Just short of wheel nut torque settings. :(
But, it still saves an awfull lot of time, as its short body gets in places larger impact wrenches can't.
Nothing beets the snappy for power though. Not even an ingersol rand, except the ir has two years warranty on battery's, snappy only 1 year.
Battery's and charger are everything with these, and iirc, the sealey ones aren't brilliant. :-\
If you can afford the Snappy, do it. Don't settle for an economic alternative, IMO of course. :y
Seth
« Reply #7 on: 11 February 2013, 23:07:22 »
TB has one I think.
All your opinions are valid lads! ;)
It's not the initial outlay ... more justifying the expense really, as I don't undertake anything like the amount of work that I previously did.
That said, maybe it could be tested-out on changing my poly donuts!
« Reply #8 on: 11 February 2013, 23:09:46 »
TB has one I think.
That's no test ..only 4 bolts a side .. you don't even take the wheels off !!!
(well . to be more honest .. Gixer didn't even take the wheels off ...  :)  )
« Reply #9 on: 11 February 2013, 23:11:58 »
TB has one I think.
Ah, see, that's where the shorter body of the Hitachi comes in. If ones jack doesn't go high enough, the body of the sealey might not fit under the sills. It cirtainly won't get on a wishbone bolt as the body is too fat. Where as the Hitachi does. It will even undo it, once its loosened first. ::) :)
« Reply #10 on: 11 February 2013, 23:13:56 »
Btw, a progressive trigger is well worth having, which the Hitachi doesn't have, the Sealey might have, but the Snappy defo has.
Seth
« Reply #11 on: 11 February 2013, 23:30:26 »
Ah well ... ya gets what ya pay for I suppose! ???
BTW Chris: What Hitachi model have you got please? ;)
« Reply #12 on: 11 February 2013, 23:44:16 »
It's this one
http://www.amazon.com/Hitachi-WR18DL-18-volt-Lithium-Ion-Cordless/dp/B000JESSTW
But you don't want that particular one as they have discontinued that battery range. You want the newer one, with slide on batteries.
Plus, mine was way cheaper from the states, and I already had the batteries so just bought the body only. £90 iirc, inlet tax.
« Reply #13 on: 11 February 2013, 23:45:42 »
Ps, snap on do a smaller 14v one iirc. Lazydocker has one. ;)
« Reply #14 on: 12 February 2013, 08:19:40 »
Yeah, think mine's the 14.4V one. It's excellent and still going strong 13 years on and after some serious abuse when I was in the garage.
Battery has seen better days but I did manage to get it to take a charge last week :y
Not sure what the torque figures are for it but it copes with most things :y And it can undo wishbone bolts :P Has a progressive trigger but is fixed torque only. Biggest downside is that it's a little bulky and heavy ::)
Would I buy another one? Absolutely! But I'd want to do some decent research to see if anything else on the market gets close :y
