Author Topic: Tyre size  (Read 3137 times)
waspy
Tyre size
« on: 06 May 2008, 22:22:32 »
I'm not sure if this post should go in General Help, so Admins please move if you see fit.
I currently run "16 wheels with the correct tyre size & i would like to go up to "18. So what tyre size should i go for to maintain the correct circumference so as not to nock the speedo out.
Help appreciated
Debs.
Re: Tyre size
« Reply #1 on: 06 May 2008, 22:36:33 »
Try using this tyre-size cross-calculator it`s quite good and will formulate a percentile rotational change factor!  :y
http://www.miata.net/garage/tirecalc.html
Albatross
  • Bedford
  • An LSD & an S2000!
Re: Tyre size
« Reply #3 on: 06 May 2008, 22:41:02 »
According to the calc then I can run 225/55 on the front and 275/45 on the rear of my Elite
Yummy But will they fit the arches?
« Last Edit: 06 May 2008, 22:41:12 by skruntie »
markey mark
  • SLady bitshorpe north lincs
Re: Tyre size
« Reply #4 on: 06 May 2008, 22:46:59 »
yes mate no worries i have 265/30r19 on front and 285/35r19 on rear  :y
Albatross
  • Bedford
Re: Tyre size
« Reply #5 on: 06 May 2008, 22:47:23 »
What J are your rims? Is it OK to run 275 tyres on those rims?
I know that my facelift car is running 265x30x19 with an effective additional offset added of 15mm wider track on each rear corner. On the front is 235x35x19 with an additional 6mm per corner, so I'm pretty sure that the tyres will fit under the arches fine..
« Last Edit: 06 May 2008, 22:48:34 by Albatross »
Re: Tyre size
« Reply #6 on: 06 May 2008, 22:49:51 »
Rims are bog standard at the mo
Re: Tyre size
« Reply #7 on: 06 May 2008, 22:51:52 »
Was gonna change the rims, but then again, what are the maximum size rubbers the standard rims will accomodate and what are the rims actual dimentions?
Albatross
  • Bedford
Re: Tyre size
« Reply #8 on: 06 May 2008, 22:54:24 »
Are you sure Markey? That's a bit out of whack; front and rear tryes are different in rolling radius by quite a chunk there.
I must admit I thought you were running 265x30x19 on the rear. If you were running 285 tryes, in truth you should be running on a profile% of 25.
That is if they made 285x25x19 tyres. I haven't seen any. :-/
Albatross
  • Bedford
Re: Tyre size
« Reply #9 on: 06 May 2008, 22:56:52 »
If you don't get an answer, find the sixe stampted onto the inside of your rims. You may need a wire brish to clean it up to see.
You're looking for a J rating which is the rim-width in inches. Then the ET number is the offset. i.e. how far out the wheel is on the car when bolted on. The lower the ET number the wider the track. The Omega is ideally ET 35-38, I think. :-/
« Last Edit: 06 May 2008, 22:57:06 by Albatross »
Debs.
Re: Tyre size
« Reply #10 on: 06 May 2008, 22:59:16 »
I wonder what percentile (front/rear) rotational difference would become 'visible' to the T.C/ABS system?
Kenny
  • Derby
Re: Tyre size
« Reply #11 on: 07 May 2008, 00:15:56 »
waspy
Re: Tyre size
« Reply #12 on: 07 May 2008, 06:46:29 »
Thank you all for your help. I shall some calculations later  :)
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
Re: Tyre size
« Reply #13 on: 07 May 2008, 13:29:19 »
Jeez, they must be bl00dy huge!! :o I have 265/40/17 on the rear of mine and I thought they were wide. ::)
Re: Tyre size
« Reply #14 on: 07 May 2008, 14:30:15 »
According to the 1st calculator then you are actually reading 1.5% too fast on your speedo.  Speedo = 60 mph / Actual = 59.1 mph.
At least its on the right side of the law
