alternative to jubilees
Started by feeutfo, 12 February 2013, 20:38:16
I doubt the water pressure hits 1 bar, unless the HG has failed...
That said, tractor used to blow its cap before its pipes....
ozzycat
 :D :D :D :D bit of baler twine and some spit chris ;D ;D ;D ;D ;D ;D
long live the magic tree
its good to be back
Quote from: ozzycat on 13 February 2013, 19:00:54
Ahh yes, duct tape, twigs and bailing twine. Holds the universe together. ...or something like that. ;D
dbdb
Some (most) jubilee clips are crap.  Some are very good, and wider so can exert more pressure over a larger area.  Mikalor are good, I'd say JCS and Norma are better. Get ones that only just fit. Or use non jubilee type hose clips like these:
or these:
Search ebay for hose clips they will all come up.
Yep, proper hose clips are better but still not the perfect solution.
Webby the Bear
slightly off the LPG discussion but i swapped over hose clamps to jubilee clips for my ''y'' pipe on my breather set up..... defo bad idea as i thought it was very tight when i had put it on.... but was loose when i came to clean them next  :o
so back to the hose clamps  :y
RIP Paul Lovejoy
2woody
#23
you could use these.....
http://www.normagroup.com/kunden/norma/ttw.nsf/id/EN_NORMACLAMP_S_SP_SD
The problem with Jubilee-type clips is that they pull up around the worm, leaving a leak path.
There's a reason why manufacturers don't use them on new cars
But, to answer your question....
http://www.jetpress.com/Products.aspx/17209/HoseClampsInstallationTools/SpringSteelHoseClamps/
Yes 2woody describes it well. It might also be a case of cheap jubilees. The clamp holding the worm is slightly bulbous to the rest of the clamp, so leaves a slight step, and hence a leak path again.
I do remember Markdtm discussing the poor properties of Jubilees, and why car makers don't use them. His words raining in my ears as I fitted the poxy things, with no other options at the time. :(
Cliffo B
Could it not be the type of join that is wrong
As already said the gm hose clips are superb for water
Perhaps a banjo type connection would be better
Say similar to the 2 fuel pipes to the plenum
dbdb
put some Heldite jointing compound on it, great stuff, seals anything.
ozzycat
Quote from: chrisgixer on 13 February 2013, 19:13:05
:y :y :y yep thats the one :D :D :D :D
its good to be back
