Omega interior mirror electric?
Started by Del Boy, 13 February 2013, 13:14:55
On an Elite should the interior mirror move electrically? Or was I dreaming?
Quote from: Del Boy on 13 February 2013, 13:14:55
Kind of... It's adjusted manually but will return to it's stored memory position electrically :y
Although it doesn't "level" ;) i.e. it doesn't rotate, just adjusts in 2 directions
Quote from: Lazydocker on 13 February 2013, 13:17:14
Ah I see, thanks mate  :y.
SMD
The other day I accidentally moved the mirror out of position but wouldn't return to its stored position
Ooh, I never knew that.. not that I've ever seen mine move - indeed if you adjust it to anything other than a small range of positions it tends to flop about as if entirely unattached (to the point you can go around a roundabout and watch it swing the other way)..
SMD
I should clarify mine moves electrically but only if its out position by a small amount. Is that how they work?
Cliffo B
What is meant by interior mirror?
Rearview windscreen mirror or external door mirrors
Quote from: Cliffo B on 13 February 2013, 15:40:59
All three should be on the memory settings.
Quote from: SMD on 13 February 2013, 15:37:51
Nope mine moves from anywhere... It is the last thing to move when holding the button though ;)
SMD
Mine can't or won't do that. I guess I might need a new one too
The ones on both our old Elites moved from any position using the memory button - as said last item to move.  Used this feature to readjust if interior mirror accidently knocked out of position ;)
