leaky windows on Tigra coupe
Started by jerry, 14 February 2013, 19:56:50
jerry
Hi,
Someone at work has a 54plate Tigra coupe(I know  ;D) and with the recent rather wet weather there is a significant leak from what appears to be the passenger side window (there is no door surround as such so the door window closes against the seal of the main car body). Apparantly this is a common fault and there is a spray that will cure it??I presume its down to a faulty seal and the spray is similar to AC50/WD40 water repellant as opposed to a sealant as such. Anyone any ideas?
        thanks
martin42
windows might need adjusting,or new door seal will be required :y
jerry
Quote from: martin42 on 14 February 2013, 20:09:59
That was my first thought Martin,(and as a cabriolet owner I guess yours is similar door-wise?), but he reckons several people have mentioned this "spray". Personally I cant see it but maybe someone on here can enlighten me?
martin42
i had to adjust the door on mine so it pulled the window close to the seal,only by 1mm which was enough
never heard of a spray tho ;)
jerry
Quote from: martin42 on 14 February 2013, 20:24:38
Maybe they mean adjust the door for a better seal first , THEN use the spray?  :-\
Quote from: jerry on 14 February 2013, 19:56:50
Hi,
        thanks
Never heard of that unless its expanding foam  :D
It simply needs something to soften the rubber seal which will have hardened and becoming depressed....plenty of options around for that
Wow a product for everything   :y
jerry
