Author Topic: help: battery flat, deadlocked and cant get it into car??  (Read 1985 times)
woolley11
  • York
    • 3.0 MV6 auto
« on: 16 February 2013, 10:38:57 »
Morning all
Just gone to the Mig (mv6 1999) to start playing with it to put on the road again after laid up over winter, but car battery flat now (which it wasnt last week - but hey ho) - the key wont open drivers door neither so effectively locked out of the car. :'(
Any easy solutions other than trying a coat hanger.
Thanks in advance for any assistance.
Omega 3.0 MV6 pfl
BMW Alpina B10 3.3 Touring
VW Mk1 Golf GTi Campaign, Triumph Dolomite Sprint
Bixy1
  • Leeds. West Yorks.
  • Hanging by a thread . . .
    • Diesel Vectra eventually.
    • Cats Tails
Re: help: battery flat, deadlocked and cant get it into car??
« Reply #1 on: 16 February 2013, 10:51:07 »
Squirt some WD40 or Lightoil (other brands are available) into the door lock and work it gently until it opens.
Cats Tails (The Adventures of Rommy and Reemy)
http://sbpra.com/derektmorgan
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #2 on: 16 February 2013, 11:02:42 »
Key in drivers door, turn hard right, pin may not come up so hand on door handle in open position while doing this should open door.
« Reply #3 on: 16 February 2013, 11:20:04 »
As above, you key will/should open the driver's door, however, years ago when I tried, mine refused to do so. Bare in mind that the lock button won't pop up as normal & you really need to use quite a bit of force to unlock it.
Failing the above .... try the boot. You can either crawl through the boot (or send a small child  ::)) to open the bonnet, or pop the boot light & apply 12 volts from another battery. That'll be enough for the key fob to open the central locking.
woolley11
  • York
    • 3.0 MV6 auto
« Reply #4 on: 16 February 2013, 12:36:34 »
thanks guys   ;D
got in in the end by forcing the key to unlock - goes against the grain to force it but it worked
ta
Omega 3.0 MV6 pfl
« Reply #5 on: 16 February 2013, 13:52:21 »
thanks guys   ;D
ta
 :y  :y  :y  :y As you say, it doesn't feel right when you think you're forcing stuff.  ;)
Page created in 0.008 seconds with 16 queries.
