focus 1.6 zetec on a 02 plate / eml light on
Started by tigers_gonads, 16 February 2013, 14:23:48
tigers_gonads
55K miles
Starts / runs ok but has started using too much fuel
A bit hesitent when cold
Thnking lambda sensor
Eml light on
Can the codes be read without a code reader ?
Not that I know of :(
What makes you think Lambda sensor? Could me any of a number of things... MAF, CTS, etc ;)
tigers_gonads
Quote from: Lazydocker on 16 February 2013, 14:27:45
Sorry, forgot to add .............. exhaust stinks of fuel (like its running rich)   :-[
Broomies Mate
#3
Not tried this myself, but according to a Focus Owners Site
    Insert Key but do not turn it on
    Press and hold the Trip Meter Reset Button
    While holding the reset button, start your car and continue holding the button
    Within 10 seconds, the display should change to "test" in LCD font and the needles will do a full sweeping. Release the Button
Pressing the button will now cycle through some 17 different modes
    1.Shows a Gauge Sweep
    2. Shows all 8's on the LCD (LCD TEST)
    3. Illuminates all the bulbs on the dash
    4. Displays hexadecimal value for ROM level
    5. Displays the hexadecimal value for EE level
    6. Shows DTC (Diagnostic Trouble Code)
    7. Digital Speedometer - mph
    8. Digital Speedometer - kph
    9. N/A
    10. Digital tachometer
    11.Fuel volume
    12. Engine coolant temperature
    13. Battery voltage
    14. ABS fail
    15. Electronic brake distribution (EBD) failure
    16. Illumination
    17. Crank Sense
I would test this myself, but SWMBO is out at the moment.
tigers_gonads
mmmm anybody got a list of codes and there meaning ?
Broomies Mate
tigers_gonads
Broomies Mate
Quote from: tigers_gonads on 16 February 2013, 14:30:34
Which many other faults could cause, including a missfire ;)
Good luck with the code reading :y
tigers_gonads
Its the brother in laws car.
The cars here but the keys are in his pocket and he has pished off into town  ::)
I don't think you will see the flash in bristol but if you cock your ear towards the north east about 17:30, you should hear the bang  ;D ;D ;D
henryd
Quote from: Lazydocker on 16 February 2013, 14:41:04
If its running rich when hot then injection temp sensor could be suspect too.
other rides
tigers_gonads
martin42
lambda sensor,2 will be fitted,blue or green plug on bulkhead,normaly its the 1st sensor that goes,the digi dash doesnt always give correct codes,obd11 reader should be able to see what codes ecu is throwing up :y
tigers_gonads
#13
No DTC codes stored but eml light is on from the start :(
Lambda sensor has a green plug
Idea's anybody
Quote from: tigers_gonads on 16 February 2013, 17:46:47
Idea's anybody
If the light's on then there are codes, just might not be able to read them without a reader ;)
You really need to read the codes before randomly replacing parts ;)
