Author Topic: Earthing  (Read 1445 times)
footloose
  • swindon wiltshire
Earthing
« on: 16 February 2013, 16:08:50 »
Where are the earthing point on the engine and body on my 3lt f/l
symes
  • oxford
    • R reg 940 volvo
Re: Earthing
« Reply #1 on: 16 February 2013, 21:35:49 »
back of engine on passenger side in corner near coil pack- :y
Andy89
  • Norway
    • 97 3.0 MV6
Re: Earthing
« Reply #2 on: 17 February 2013, 01:05:48 »
The main earth point is on the bracket that holds the powersteering pump and ac pump?? (not sure on facelift but I doubt they've moved it)
Earth point for the body is under the battery tray if i remember correct
There is 3 earth points for the engine harness where symes said.
« Last Edit: 17 February 2013, 01:07:24 by Andy89 »
footloose
  • swindon wiltshire
Re: Earthing
« Reply #3 on: 17 February 2013, 08:51:48 »
Thanks fellers i'll have a look today. I suspect corrosion where it's earthed to the body.  :y :y
Re: Earthing
« Reply #4 on: 17 February 2013, 10:50:18 »
There are no earth points but plenty of grounds (0V)
Re: Earthing
« Reply #5 on: 17 February 2013, 14:30:44 »
I nearly started a sweep stake at how long it would take for a post from you!  ::)  ::)  ::)  ::) ;)
