Author Topic: Misfire and almost no power - just about crawled home in 1st  (Read 1158 times)
steve6367
With the following data:
Coil pack? Or anywhere else I should be looking?
      Fault codes
            Fault code Code status Code type Definition
            P0301 Stored Generic Cylinder 1 Misfire Detected
            P0304 Stored Generic Cylinder 4 Misfire Detected
      Freeze Frame data
            Fault code Sensor Value
            P0301 Sensor values:
            Calculated Load 90.98 %
            Coolant Temperature 84. C
            Short Term Fuel Trim Bank 1 -2.34 %
            Long Term Fuel Trim Bank 1 -12.5 %
            Short Term Fuel Trim Bank 2 -100. %
            Engine Speed 1969 rpm
            Vehicle Speed 10 mph
            Ignition Timing Advance 63.50 º
            Intake Air Temperature 33.00 ºC
            Air Flow Rate (MAF) 0.00 g/s
            Absolute Throttle Position 7.06 %
            Oxygen Sensor 1 - Bank 1 voltage 0.41 V
            Oxygen Sensor 2 - Bank 1 voltage 0.42 V
            Fuel System 1 Status Closed Loop
      Onboard test results
            On-board test Current status
            Misfire monitor Completed
            Fuel System monitor Completed
            Components monitor Completed
            Catalyst monitor Completed
            Heated Catalyst monitor Not supported by car
            Evaporative System monitor Completed
            Secondary Air System monitor Not supported by car
            A/C Refrigerant monitor Not supported by car
            Oxygen Sensor monitor Completed
            Oxygen Sensor Heater monitor Completed
            EGR System monitor Not supported by car
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Misfire and almost no power - just about crawled home in 1st
« Reply #1 on: 18 February 2013, 19:59:26 »
Pull your coil pack out and see if your plug wells are full of oil
Abiton
« Reply #2 on: 18 February 2013, 20:37:13 »
MAF reading zero is surely key?  ???
Have you tried unplugging it?
« Last Edit: 18 February 2013, 20:41:25 by Abiton »
« Reply #3 on: 19 February 2013, 07:35:44 »
Yes maf 0.00 can't be right with 90% throttle load.
steve6367
« Reply #4 on: 20 February 2013, 16:43:05 »
I have a seperate thread running about my MAF here:
http://www.omegaowners.com/forum/index.php?topic=111582.15
Changed the coil pack for one I got as a spare from breakers a while back and all ok again now - nice round trip Bournemouth to Portsmouth and back so pretty sure its fixed :-)
Thanks for all the tips.
Steve
