Author Topic: Alarm  (Read 1659 times)
cleggy
Alarm
« on: 21 February 2013, 09:02:25 »
The power sounder is exterminated but every since this cold weather the hazard lights are forever coming on. I have lifted up the under bonnet sensor to no avail and can't think of any other reason for them to flash. I have taken to leaving the car unlocked on the drive but not an ideal solution. Any ideas
pauls
  • By the sea minehead
    • Bmw x3
Re: Alarm
« Reply #1 on: 21 February 2013, 10:09:58 »
Have you tried unplugging the bonnet sensor. My was doing the same so I unplugged it and all is well now.
cleggy
Re: Alarm
« Reply #2 on: 21 February 2013, 11:35:35 »
Cheers pauls I'll try that :y
Re: Alarm
« Reply #3 on: 21 February 2013, 15:39:56 »
Being an estate also check the sensor connections for the rear glass
cleggy
Re: Alarm
« Reply #4 on: 21 February 2013, 16:02:28 »
Cheers, I check that one regularly, because of the two labs in the back ;) :y
cleggy
Re: Alarm
« Reply #5 on: 26 February 2013, 08:09:34 »
With the bonnet sensor dissconnected and the rear glass sensors checked it is still doing it :( :(
Any more ideas   :y
Re: Alarm
« Reply #6 on: 26 February 2013, 08:12:00 »
Pop round and I will read the codes (car pass may be required)
cleggy
Re: Alarm
« Reply #7 on: 26 February 2013, 08:20:57 »
Thank You Mark, can you PM me with your details etc. please
Re: Alarm
« Reply #8 on: 02 March 2013, 22:34:09 »
So, is it any better?
For those who posted, rear window break detectors were the fault so config changed to address it
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
Re: Alarm
« Reply #9 on: 03 March 2013, 00:47:27 »
mine was the same, so i unplugged them then on live data shows not connected so thinks its a saloon
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
