Author Topic: Automatic Gearbox Oil Level Check...  (Read 3146 times)
OmegaAnglesey
« on: 21 February 2013, 17:42:20 »
Is there any picture guides on how to do this ? ..Apart from this  :-\
http://www.omegaowners.com/forum/index.php?topic=90508.0
Can't say I've checked it since I've had it.
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Automatic Gearbox Oil Level Check...
« Reply #1 on: 21 February 2013, 17:55:14 »
I think if you undo the filler plug, fluid will escape if the level is ok? If there is no drainage then top up required  :y
Stand to be corrected though  :-X
OmegaAnglesey
« Reply #2 on: 21 February 2013, 17:58:33 »
Sounds complicated  :o ... Wont be giving this a go anytime soon, Was just washing the wheels and in 1 hour (in daylight) the water turned to ice  :o
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #3 on: 21 February 2013, 17:59:01 »
Theres not really anything to it mate. youre looking for the 13mm level plug on the transmission pan.
run car to temp.
level surface, jack drivers side and support on stands
loosen 13mm plug.
start car.
take out plug.
fill.
let back down to drain.
once fluid stops coming out, rejack up and refit plug.
wipe up excess.
done
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #4 on: 21 February 2013, 18:00:05 »
....and pic 2 shows the level plug youre looking for...
http://oldsite.omegaowners.com/forum/YaBB.pl?num=1289757627/0
RIP Paul Lovejoy
OmegaAnglesey
« Reply #5 on: 21 February 2013, 18:04:47 »
Thanks Webby, That gives me an idea where to look and a good guide there to boot. Just need to get some warm weather.
Webby the Bear
  • Northampton
« Reply #6 on: 21 February 2013, 18:06:43 »
no probs mate..... i'm presuming the 2.2 is the same but i'm sure if i've got it wrong someone will be along to tell you/me :)
the only thing you need to make sure is you dont get under the car unless its on good quality axel stands. oh and the cat is hot so watch out for that :)
RIP Paul Lovejoy
OmegaAnglesey
« Reply #7 on: 21 February 2013, 18:14:59 »
Was just looking on Google and found this..
http://www.justanswer.com/uk-car/5f299-vauxhall-top-fluid-level-automatic.html
Someone asking a similar question to mine and the "Expert" says "If you don't have a leak then I wouldn't bother with it."
True, but it should still be checked surely.
Webby the Bear
  • Northampton
« Reply #8 on: 21 February 2013, 18:22:08 »
Someone asking a similar question to mine and the "Expert" says "[size=78%]If you don't have a leak then I wouldn't bother with it."
i think (again correct me if i'm wrong peeps) that under ''normal driving conditions'' you dont need to touch it. there is also some folk who believe that REPLACING the fluid in a transmission where the fluids never been changed have seen them fail shortly after due to the new fluid oxidising the internal parts.
however i know the folk on here believe a routine (70k miles???) change should be adhered to.
me personally am going to do just a top up (like you). i have 98k on clock and no evidence its ever been changed. and the car doesnt exactly have a hard life. so just a top up will be good enough in my mind.
as said though this is just what i'm going to do personally and i'm just commenting on what other people have said  :y
RIP Paul Lovejoy
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #9 on: 22 February 2013, 11:17:38 »
Webby just for clarification is the engine still running when you drop car down to drain to level.And then I assume that you jack up again to get plug back in (not much room under there.
« Reply #10 on: 22 February 2013, 11:33:20 »
YES  ... level check is done with engine running, gearbox in neutral, system at normal temperature :)
Webby the Bear
  • Northampton
« Reply #11 on: 22 February 2013, 12:03:05 »
do you guys think it would be an idea to spray a bit of penetrating oil on the drain plug if it's never been off the car???
RIP Paul Lovejoy
« Reply #12 on: 22 February 2013, 12:05:31 »
You can never use too much PlusGas  ;) ;)
Webby the Bear
  • Northampton
« Reply #13 on: 22 February 2013, 13:04:06 »
[quote author=Andy B link=topic=112356.msg1415713#msg1415713 date=13615347
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #14 on: 22 February 2013, 13:04:20 »
 :y :y :y :y
RIP Paul Lovejoy
