12 v Power inverters
Started by doz, 24 February 2013, 15:29:11
doz
If I wanted to run a laptop which is rated at 1.7 amps. What rating would I need on the power inverter?
tidla
W
IxV
1.7x12
21w
200w should be plenty
Quote from: doz on 24 February 2013, 15:29:11
I assume thats at 18-20v?  On the face of it, 100W should be enough, but inrush currents on SMPS may be too much.
Inverters aren't particularly efficient, and will soon kill a car battery if the car isn't running.
Most laptops should last 4-5hrs with ease. Would a 2nd battery, or a high capacity battery, be a better option?
doz
It's for the camper. Has a split charge and twin batteries.
Abiton
I used a 300W to run a laptop last time I went camping , with no problems.  It has an inbuilt 'you've taken the piss' low-battery-voltage audible warning so I didn't have to be anxious about the car starting.  Said alarm never went off though.
Had a 2kw one on the boat, powered by two leisure batteries. Would power an A rated Bosch fridge for three days on its own, but put the telly on with the heating and four hours was its limit ::)
Wasn't such a big deal though, as the engine doubled up as the boiler for the hot water, so was run for 2-3 hours a day :y
Quote from: tidla on 24 February 2013, 15:36:24
W
IxV
1.7x12
21w
Where did you get 12 Volts :-\
Got two laptops in front of me & one requires 15V the other 19V.
The most efficient way would be to get hold of a switch mode "step-up" regulator to take anything from 11V-14.5V and output whatever the laptop requires.
ZacVegas
I run my laptop from a 90watt inverter I got from towsure for 17quid  :y
doz
Laptop is rated at 110-240 1.7 amp. Output is 18 volts
Quote from: doz on 24 February 2013, 20:01:49
Jeez :o
How old is it?
1.7A at 110v puts it just shy of 200W :o :o :o
Sure you've read it right?
doz
Yep. It's fairly old. Running XP. It's an old one I use in the garage and not to bothered about it
ozzycat
i run a 300w invertor this enough to run the battery charger on my scooter when its in the car
long live the magic tree
its good to be back
tidla
the volts pushing the 1.7 A is 18v.
1.7x18=30w
dbdb
#13
Quote from: tidla on 24 February 2013, 22:00:57
1.7x18=30w
Spot on. So that's approx 30W at 230V too.
Generally you need at least double the wattage of inverter (because inverter manufacturers lie, basically) so a 100W inverter would be fine, putting out over 30W at 230V into your charger which then wastes a bit and puts out 30W at 18V to your laptop. Alternatively you could get a 12V to 18V inverter and bypass your charger, I know these are available for small loads. Frankly though for a laptop it is probably not worth risking the voltage being out, not to mention wrong polarity and ac/dc issues. In fact if you get an inverter best to get a pure sine wave one. Twice the price but a modified sine wave one often blows chargers.  Lots of reasonable and cheap inverters available from China on ebay.
doz
