Buying a used car guide...
Started by Webby the Bear, 25 February 2013, 21:15:53
Auto Addict
Quote from: chrisgixer on 01 March 2013, 10:10:05
Given the amount if slop available with subframe positions, I would NOT give too much attention to wheel position. Unless its obvious. In which case, well, it will be obvious. ;)
Well, I thought that would be obvious.
I like red cars
if you dont compare both sides by measurement you will see nothing..
Webby the Bear
Thanks for all the input guys. Engine has a cover on it that is screwed in with 4 bolts. And it has 4 coil per plugs....
is it reasonable to ask to unscrew cover and remove these (bolted down also) to check for oil in't plugs?  :y
RIP Paul Lovejoy
henryd
Quote from: Webby the Bear on 02 March 2013, 23:01:28
Probably going a bit far tbh ::)
other rides
Quote from: henryd on 02 March 2013, 23:59:26
Unless perhaps if there were signs of smoke or strong smell of burning oil, may then be worth a look..... :y
doz
Before you leave to look at the car look up the address on google earth. If the place looks like Beirut after another slanging match for the love of God don't go. I also feel this http://www.omegaowners.com/forum/index.php?topic=100502.0 Should be made required reading. It may save you from a harrowing experience
dbdb
can't you just pull the plug lead out without undoing any bolts?  You can on my f/l V6 and my previous 98 V6.  Oil will be obvious on the lead end.
Quote from: doz on 03 March 2013, 01:21:38..... I also feel this http://www.omegaowners.com/forum/index.php?topic=100502.0 Should be made required reading. It may save you from a harrowing experience
;D ;D ;D ;D  I'd forgotten about that  ;D ;D ;D
