DTi Inlet manifold
Started by Elite Pete, 26 February 2013, 18:21:31
This is what you'll probably find when you remove the inlet manifold or your DTi, it takes some cleaning but it's well worth it ;)
twiglet
Thanks Pete, really looking forward to this job now!  ::) ;D
I've got another set already cleaned and ready to fit. Cleaning them up is the worst part of the job :'(
twiglet
Quote from: Elite Pete on 26 February 2013, 18:36:58
What did you find worked best in getting rid of the crud Pete?   :-\
I'm thinking SWMBO's dishwasher!!  ;D
twiglet
twiglet
Quote from: Elite Pete on 26 February 2013, 18:46:56
Quote from: VXL V6 on 26 February 2013, 18:45:36
I used paint stripper  :y
Yeah, Nitromors and carb cleaner :y
Lovely! Cheers!  :y
Did/will you fit new GM gaskets?
henryd
Isn't oven cleaner meant to be good as well ???
other rides
Yes but it attacks alloy, paint stripper is fantastic at cleaning car parts
spud1990
mine was just like that on my vectra. i used some strong wheel cleaner<acid> from work. it made them look like new :y :y :y
joff
done a few of them now, used a copper or alloy blade to remove bad bits and then carb cleaner and non dealer gaskets worked fine and engine runs a lot better. :y also check the rubber elbows at the back of the engine as the get hot back there and let air into vac system
Quote from: twiglet on 26 February 2013, 18:48:08
Lovely! Cheers!  :y
Yeah, there are 2 metal ones which IIRC they cost less than £5 from the dealers ;)
