Author Topic: Oil Filter  (Read 1474 times)
Johnnyc
  • Huntingdon
    • Omega CDX V6
Oil Filter
« on: 28 February 2013, 21:31:02 »
Not sure if this has been asked before,iv'e tried to remove the oil filter and will it come off  will it ####!! Any tips as i don't want to damage the housing.Cheers.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Oil Filter
« Reply #1 on: 28 February 2013, 22:29:11 »
is it the housing/paper element filter ?
RIP Paul Lovejoy
kevinp58
  • kent
    • 2002 3.2 elite
Re: Oil Filter
« Reply #2 on: 28 February 2013, 22:58:31 »
If it is the paper element one you need to get a long bar with the socket on it and it should come off I had the same problem and it broke the web off inside the casing I have since changed it to the canister type much easier  :y
Re: Oil Filter
« Reply #3 on: 28 February 2013, 23:10:22 »
Some have used a strap type filter remover on the housing base to hold it in position while the ally filter housing is removed.
It's a recurring theme of over tightened housings that won't come off. The torque of 25Nm really is only just a nip .....
Johnnyc
  • Huntingdon
    • Omega CDX V6
Re: Oil Filter
« Reply #4 on: 01 March 2013, 21:47:00 »
Cheers for the advice,it is a paper element.Have tried it with a long bar so will give it go with the strap holding the housing.Thanks again everyone!! :y
Re: Oil Filter
« Reply #5 on: 01 March 2013, 22:34:11 »
I'd tend to shock it undone ie a universal 2lb knocking stick onto a spanner rather than a long lever  :-\
