Author Topic: 'Another' boiler question.  (Read 1534 times)
Jusme
  • North Hykeham, Lincoln.
    • Lexus LS430
« on: 01 March 2013, 00:39:54 »
Seems to be that time of year again ?? The problem I have is, the boiler fires up for about a minute every 10 minutes or so, night and day even when the heating is off. Can't be anything to do with frost protection in these balmy days of 3 - 4 degrees.. I suspect an electrical problem ? So is it a job for an electrician or a plumber ? Thinking about 'gas safe'. Any help would be greatly appreciated..  :y
Under-steer is when the front of the car hits the wall, and over-steer is when the rear of the car hits the wall.
Power is how fast you hit the wall and torque is how much of the wall you take with you.
martin42
Re: 'Another' boiler question.
« Reply #1 on: 01 March 2013, 12:38:10 »
what boiler is it to start with,
« Reply #2 on: 01 March 2013, 12:44:56 »
If it's a combi boiler with 'instant' hot water, do you have it set to keep it's tiny little reserve of hot water hot? Mine can be set to do that too (and was, on installation)..
Jusme
    • Lexus LS430
« Reply #3 on: 01 March 2013, 12:45:27 »
Oooops!  :-[  Ideal Classic FF270..  :y
redelitev6
« Reply #4 on: 01 March 2013, 12:46:31 »
Faulty thermostat ?
« Reply #5 on: 01 March 2013, 12:47:50 »
Depends on the installation, but ours did this due to a faulty microswitch in one of the motorised valves (same type as used in an Omega's door locking motor, and just as reliable). ;D
Jusme
    • Lexus LS430
« Reply #6 on: 01 March 2013, 12:54:27 »
I did wonder about the thermostat, but how would that control ignition of the boiler when the heating is switched off? I have read through absolutely masses of information on the net regarding this very issue, but of course many might be slightly different? Then of course there is the fact that, as soon as people start getting technical my 'extremely old' brain just goes into 'shutdown mode'...  :-[
Page created in 0.013 seconds with 14 queries.
