Help SPI
Started by omega3000, 01 March 2013, 12:59:18
I'd like to service my single point injection .. pic
Where do i start and what bits need to be taken off and cleaned  :-\ Pug 106 1.1 .
Any advice appreciated  ;)
henryd
Quote from: EMD on 01 March 2013, 12:59:18
If it aint broke don't fix it :P,just use carb cleaner on what you can see :y
other rides
QuoteIf it aint broke don't fix it ,just use carb cleaner on what you can see
Thats what i thought henry to just use carb cleaner but sure M'DTM said that wont clean what needs to be cleaned  :-\ This picture isnt mine , i need to take mine off . So when its off just soak it in carb cleaner  :y
the alarming man
was mark refering to taking it all too bits as carb cleaner the clue is in the title :y
I'd just attack what you can see on the butterfly with carb cleaner & an old tooth brush
Quote from: the alarming man on 01 March 2013, 13:31:21
Yes i think he mentioned that just spraying it wont clean the internals  :-\
Quote from: Andy B on 01 March 2013, 13:42:36
I think thats the only way i can see how to do it andy , knowing my luck if i take it to bits some springs or something will fly out and never get them back in  :(
Ill take the blighter off anyway and see what i can clean with swmbo's toothbrush  ::) I noted it was a bit gummed up the last time the top was off , will check the vacuum pipes as well  :)
I was actualy referring to the fact that redex would not clean it.  :y
Clean both sides of the throttle butterfly and throttle body throat with carb cleaner, also do all the breather ports and the upped throttle body face.
Quote from: Marks DTM Calib on 01 March 2013, 13:57:14
Arh right gotcha  :y Will give it a good cleaning then . Cheers .
Quote from: EMD on 01 March 2013, 13:45:04
What can I say but  :y :y :y
