Author Topic: Corsa brake discs......2003 1.2 SXI  (Read 1688 times)
« on: 02 March 2013, 13:29:51 »
Looking through the slots in the front wheels, the discs appear to be vented.
However, the genuine GM parts I have ( GM 9195981) are solid.
Is this a problem?
Thanks, Chaps. :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Corsa brake discs......2003 1.2 SXI
« Reply #1 on: 02 March 2013, 14:16:33 »
Yes if you try to fit them :o,if its got vented then thats what you need :y
other rides
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #2 on: 02 March 2013, 14:26:55 »
Been caught out with Corsa discs before, even the dealer system can screw up ::)
« Reply #3 on: 02 March 2013, 15:03:58 »
Thanks , Henry and Omegod. :y
I'll take them back to the dealer.
Are the pads the same for vented and solid discs?. If not I'll also need to return those (GM 93176114)
« Reply #4 on: 02 March 2013, 17:44:22 »
According to the Corsa forum, the 1.2 has 11mm solid discs if non-abs.........or 20mm vented discs if the car is fitted WITH abs.
Mrs Opti's pride and joy has abs :y
.......they also say that a hex socket ??? ??? is needed.
« Reply #5 on: 03 March 2013, 10:40:01 »
I'll wager that I have to pay extra for the vented discs.
Can someone tell me the GM part number please. :y
tidla
  • solihull
« Reply #6 on: 03 March 2013, 15:18:17 »
No clue to the part no, pretty sure they will insist you have the gold plated ones though.
« Reply #7 on: 03 March 2013, 20:28:17 »
9195985 for the discs (which are £1 cheaper than the solids)
93182590 for the kit (which is much cheaper than the discs alone but more expensive than the solid kit).
Page created in 0.027 seconds with 16 queries.
